Huskey
This is overdue but I cleaned her today and crawled under for some pics so here goes...
Her name is Suzie, but I have called her much worse. She's an 05 Limited, 4.7 V8. Original Suspension was Rear Adjustable Suspension (RAS) with XREAS.
Current Suspension:
For the rear - Long travel Trail Gear leaf springs with bilstein 5100s. For the front, 6" Pro Comp adjustable coilovers designed for an FJ. Alot of work was done to make it all fit.
Here's the rear:
Bilstein 5100s upper bracket
Lower mount, Naked axle on the leafs, abs and brake lines (left side)
Right side
Magnaflowcat back, tweaked to fit above the leaf spring
The leaf (left side)
New brake lines
35x12.5.R20 Nitto Trail grappler on Iron Eagle wheels
Current Suspension:
Here's the rear:
Right side
New brake lines
