Tested the "spool" this weekend, works great! Snow is starting to melt so I didnt get stuck in the field this time. Hopefully next sunday I can make it up into the woods a bit.
Got my doors on, but they dont open. Only held on by the top hinge and the latch. Going to cut them down a bit more then cap them off. They will still be quick release.
And started on the next step. Found a good deal on a Advanced Adapters R150F to Gear drive box plate. Plan is to run a single 4.7 case. Im fine with a 35 Mph low range top speed, It gets trailerd everywhere. And this way I can still use my Budbuilt and existing drive shafts.
Edit: Some more info
Types of toyota stuff:
http://www.4x4wire.com/toyota/faq/parts/
The truck has a R150F tranny with a chain driven VF1A Case. Has a 2.57 low range and is 23 spline. Strong, good case, but no aftermarket support.
I need an adapter to go from the r150f to the top shift case. The tranny is 23 spline, while all gear drive set cases are 21 spline. I either need a conversion gear in the crawl box (If I find a used set, sometimes can find a used box with gears for 3-500) or If I buy gears new, I can get 23 spline a input from the start.
I want to run a single 4cly top shift gear box behind the r150f to keep it simple. RF1A boxes are 2.28 reduction, but with a set of 4.7 gears, it makes it worth it. Duals would be cool, but this is simpler. I can always add another case down the road if I want to.
Very informative thread:
http://www.yotatech.com/f116/v6-tran...r-case-231669/
