robotkiller
Thanks everyone for your replies. Let me tailor the question a little more.
Are there any Trail owners w/KDSS that have upgraded to the Bilstein 5100's? If so, how does this setup compare to stock?
For those of you that have run spacers, do you need front and rear or just front? Does your 4runner handle much differently with spacers or is it just 1 or 2 inches higher and pretty much handle the same? I do understand the higher you raise the vehicle, the higher your center of gravity.
I like the idea of a simple cost effective spacer lift although I will spend whatever I have to do it safely, effectively, and correctly the first time.
I too, only want it an inch higher...anymore will give me parking issues etc as I drive for work and am in the city allot and need to deal with parking garages, etc.
I have KDSS w/Bilsteins and a rear spacer. The Bilsteins have superior compression dampening and handle small bumps, chatter and large dips with better control than the stock struts. If you are going to the trouble of spending $200-300 to install a lift and alignment, I'd at least go with Bilsteins. Excellent bang for your buck.
I chose the 1.5 inch rear spacer because I have ~90lb of static weight on the rear end of my truck. Without that, I think a Cornfed 1 inch spacer would be probably be well matched to 1.75 Bilstein front end lift.
With the lift, my center of gravity is higher, so cornering is not as good as it was before when I'm really pushing it (which is not often). I don't notice it in daily driving and the car feels solid and doesn't wallow or feel boaty. Steering seems about as precise as before, maybe a hair less buttoned down.
The truck feels and looks bigger (in a good way) and ground clearance is definitely much better. I think it's a worthwhile upgrade. I may eventually ante up and go for custom coilovers, UCAs and 285s. We'll see.
