I made some rear bump stops. what do you think?
Nice work and very very cool
[MENTION=146407]Plastics guy[/MENTION] your 5.25” bump stops for a 3rd Gen 4Runner states, “intended for stock suspension trucks or mild lifts up to 1.5″. I have a 3” lift. Would these work or do I need taller bump stops?
It depends on how you lifted your 4runner. If you just put in taller springs that increased the ride height, you would want the 3.5 bumps. If you also installed longer shocks that don't compress as much as the stock shocks you will need the 5.25 bumps.
You want the bumps to be able to fully compress before the shocks bottom out.
Yep. And the only way to know, and understand for sure, is to remove your coils and cycle the suspension. Once fully stuffed with the shock fully bottomed take a tape measure and measure from the axle to the frame. Whatever that number is will dictate what length bump you need. It's so easy to do yet hardly anyone does. They just guess. lol
I installed the OME 861 springs and Bilstein 5100 shocks. Probably will go with the 5.25 bumps.
If the Bilstien shocks are for a 3rd gen 4runner you will want to use the 3.5" bumps. If the shocks are for a Tundra then yes, get the 5.25 bumps.
I can tell you...you dont want to bottom out the shocks....often anyway...blew through some and the only thing I can think of is that they bottomed out a few too many times
That's for the 1999-2006 Tundra. the ones for the 4Runner are for 0 - 2" of lift only
Thanks for confirming that! I wasn't sure if they were from a Tundra or not since this was the first time buying from Wheelers, not knowing if they would utilize interchangeable parts.
[MENTION=146407]Plastics guy[/MENTION], I just bought these. Recommendation from [MENTION=120071]mtbtim[/MENTION]
ghengiskhan
