i need help!
idk???
so i out in a new differential along with axles and basically everything. i got a 93 v6 4x4 and only 70k miles :) but now idk why but after i changed it when i drive and let go of the gas it drops into a lower gear. then i turn the car off. wait a lil and it goes fine.. so its like a glitch.. if anyone could help plz do!
your right you need help go back to elementary school and learn to write and grammar and all that because i cant make out what you changed something about axles and junk?
your tranny may need a new filter or your overdrive selinoind has failed
Hello , look at your comment, now back to mine, now back to yours, now back to mine. Sadly it isn't mine. But if you stopped using short form and switched to proper grammar instead, it could look like mine. Look down, back up... Where are you now? You're on the forum page with the comment your comment could look like. What's in your hand? Back to me. It's a keyboard, with letters composing the English language that you love. Look again and the comment is now EPIC. Anything is possible when your comment is properly written, and not in short form. I'm on a chair.
Says the man with no punctuation or capitalization. :D
Allow me to translate:
The car is a '93 3-VZE 4WD with 70k miles.
He put in a new differential and axles, along with "everything else" . After putting all of this stuff on, whenever he takes his foot off the gas, the car downshifts. If he turns the car off and waits, it seems to fix itself.
There, that wasn't so hard, was it?
Now, what we need from you still:
Is this an automatic or a manual? It sounds like an automatic from the description, but I can't be certain.
What exactly did you change out? Front differential? Rear differential? Both? Rear axles? Front axles? Both? What is "basically everything"?
When you stop the car and re-start it later, does it work perfectly with no downshifting problem, or does it continue to do this? Does the problem only occur after a cold start?
Honestly though, this sounds like something you should take to a mechanic (preferably a transmission specialist) for a diagnosis. It's pretty hard to pinpoint a problem like this over the internet. Most likely, you screwed something up in your installation, but with all the work that you did, there are a thousand different things that could be wrong.
