I noticed today the "Slip Indicator" light didn't come on at start up...
Jeff T
Member
Then with a little snow on the ground it didn't come on when the tires slipped either.
Is that a replaceable bulb???
How the heck do you get at it??
Thanks!!
I'm sure the bulb is replaceable and getting the cluster out is pretty simple too. With a simple search you'll be able to find a thread with pictures.
I love these write ups that start with half the dash already apart!!! If I read it correctly the outer bezels will just pull off and then have the access to the cluster???
Thanks, I interpreted one set of instructions as the bezel was separate from the dash, that was my mistake. Now I see what I need to do. Looks like it will wait til spring time!!
pulling the cluster literally takes 2 minutes. 2 screws at bottom of panel below steering wheel, pull it off, pop off the black panel around the bezel, unhook 2 plugs on back (dimmer and something else)
remove 3 screw 2 bottom one top for the cluser, (dull grey) unscrew shiny gold screws that hold on wiring harnesses and its out, i did it about 7 times when doing the led swaps. on a second note it IS NOT a bulb, it is an led that is surface soldered onto the board. check out http://www.toyota-4runner.org/4th-g...ster-hvac-switches-window-steering-wheel.html
for pics from there on. page 4 has more pics, and some after that. i did radio and dash led swap took probably 4 hrs total. (the switched are harder to put leds in, the soldering on the board os waaaay eaiser.
ciao
Cpn2mss
