Icon Suspension CDC Valving - What numbers do you run and when??
m10karind
Alright, who has the Icon coilovers and or rear shocks with the adjustable compression damping control valving(CDCV)? How do you like it and what numbers are you running for different terrain types and driving styles? I have the adjustable coilovers up front but honestly haven't played around with them too much. They're set to 4 now which is what the regular Icon's come as, and I really like how they feel. It's my daily driver and I also drive a good amount on dirt roads with wash boards and what not. I can go SO much faster on the washboards now vs. stock(25mph before and 70mph now!) Anyway, I'm going to play around with the adjustments more and see if I can get it better for different applications and see what I like. Just seeing what others opinions and experiences are.
From Icon:
The ICON CDC Valve is an externally adjustable valve that restricts oil flow into the reservoir creating 10 levels of compression damping force ranges. Controlling the amount of oil flow externally allows optimizing of ride quality for varying terrains. With the addition of an ICON CDC Valve a different tune is required on the working piston to get the ride quality range of adjustment to softer than standard at the “S” setting and much firmer than standard at the “H” setting. The ICON CDC Valve piston is custom tuned per application with different valve stacks because not all shocks or applications are equal. Adding on the CDC Valve is not a one size fits all if you want optimum performance. The CDCV external knob allows for 10 levels of adjustment. Each detent from S-H is a noticeable difference in ride. When engineering this feature into each shock application, the main shock piston is re-calibrated such that setting “4” is equivalent to the non CDCV version. This allows for both a softer and firmer ride than the same application without this option. The ICON CDC Valve brings a new thinking to the table with an upgrade option that offers true ride quality diversity.
Here's a photo of my coilovers and UCA's.
Daily driving I run 6 in the front, 5 in the rear.
Long road trips on the highway I step it up to 10 (H) in the front and rear.
Offroad I usually go to 1 (S) front and rear.
