If You Off-road Your 5th Gen with P-metric Tires Please Vote
Have You Had a Blow-out with P-metric Tires Off Road?
  • Total voters
    145
What's a blow out? Do you mean a flat? An unfixable flat? Sidewall tear?
I've had one flat on my P285/70/17's. I would not buy LT tires for my mixed use nor do I particularly want them. I would use them if I buy a second set of wheels/tires for offroad only. A P285/70/17 is rated for more load than an LT265/70/17. I prefer the softer more pliable casing for the 95% of my miles that are highway.
I'm not sure that a tire's load rating necessarily equates to sidewall strength, e.g. BFG TAKO2 c rated stock size is 6 ply, but has a load rating lower (112) than stock tire spec (113).
2016 SR5P 4WD Super White
Bilstein 5100 @ .85
Nokian Rotiiva AT 265 70 17
I can add some timely advice here.
Week before last I went wheeling in southern CA with a group of 11 trucks.I had been second guessing my decision to go with p rated tires, so I checked out everyone's tires before we hit the trail. 8 LTs and 3 P's including mine. One of the P's slashed a 3 inch gash in a sidewall .5 miles into the first trail. I made it to the end of the day but realized after the fact that I picked up a slow leak... in the sidewall...tire ruined.
Flashback...in November I realized that LT265/70R17 and LT275/70R17 tires would not fit my 17x9 wheels but that P265/70R17 would. After reading endless posts I decided that most of the people dissing p-rated tires didn't have any real experience with them. I'd driven several dirt roads and a couple of more serious trails on the stock tires and survived so figured a set of p rated AT tires would be fine and would cost a lot less than getting new wheels and tires. 4 months later I am getting the new wheels and tires anyway, a costly mistake!
Most of my driving is on pavement but when I do get off road, the piece of mind of LT tires is worth the price. 275 BFG KO2s going on tomorrow at which point I will be really busy updating 50+ threads on whether they rub or not. :thumb3:
-slide
What car takes 265 70R 17 tires?
Plenty. All crossover "suv's" do. P is passenger rated and a lot of 1/2 ton trucks even come with them. Is that right? For some if not most all they work. Those that start to venture off-road or carry or tow weight...a proper LT tire is advised. Manufacturers use the cheapest and lightest tires to get the best fuel mileage for EPA mandates...not necessarily the tires you will abuse with weight or tearing up off-road.
People can run p rated tires on their trucks without issue. Nobody is going to die doing so. But if you load up your Runner with lot same of weight, I believe lawndart has one of the heaviest runners on here at 6800 pounds or so, that is what my megacab 3/4 ton 4x4 Cummins weighs! No way would I put p rated tires on that.
Point is....p rated is exactly what they are. For use on road, light, good fuel mileage and works for light off-roading (not really requiring airing down). This is the demographic for the SUV's, the 1/2 ton trucks, and other vehicles that never go off the pavement or carry weight.
Run what you brung is a motto I've heard often and my personal experience has lead me to some important things such a simple thing as good tires, working vehicle, SOME recovery gear, a comm device, common sense or open ears to learn.
Again, do what you want and if it works great! I run 16 ply 19.5's on my Ram since I carry a large overhead camper and tow a boat. 8200 lbs of scaled weight on just my rear axle dictated that.
I was concerned about the Nitto TG on the TRDP when I got it...figured I'd slash sidewalls and have other issues. I'd planned on running them for a Baja trip and seeing how they did.
So far, I've taken a nail at a mining site in the Kofa Wildlife Refuge in Arizona, but the tires have done 3 Mexico trips, the entire Mojave Road and Death Valley...with no issues.
I'm actually kinda impressed!
Now...when these are done I'm certainly going with a stronger tire, but for now, so far so good!
-H-
Amazed by P rated Toyo ATIIs
Have had my '15 Trail for just over 18 months. first mod was rims and tires. I was (still am) a newbie to offroading. Bought the Toyo ATIIs about a month after purchase.
Wife and I took to wheeling quickly.
Have taken these P rated tires all over Big Bear, Moab, Barker Mtn (Tahoe), Death Valley, Joshua Tree, local SoCal trails. Also tow a 3000# trailer regularly.
Shockingly not a single flat. I keep waiting to lose a tire (crazy statement?!?!?), but to my fortune, not yet.
Deflators set to 20psi, so guessing the tire flex is helping to minimize puncture threats??? Tire placement and luck are also a big part of it.
Next set will probably be Nitto Ridge Grapplers C rated for more piece of mind. Es would be too much (stiff, heavy) for my needs.
HOWEVER, amazed at the durability of these Ps.
The load range/ply rating branded on a tire's sidewall identifies how much load the tire is designed to carry at its industry specified pressure. Passenger tires feature named load ranges while light truck tires use load ranges that ascend in alphabetical order (letters further along in the alphabet identify stronger tires that can withstand higher inflation pressures and carry heavier loads). Before load ranges were adopted, ply ratings and/or the actual number of casing plies were used to identify the relative strength with higher numeric ratings or plies identifying tires featuring stronger, heavier duty constructions.
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
True, but the side wall is the major concern (at least for me). The main tread can be plugged easy enough with well, plugs. Those are easy and honestly, not a worry for blow outs going down the road.
Side walls with heat build up and compromised plies...is something that tire shops won't touch even though I've plugged side walls in the past.
Your right, you have to look at the tires actual construction to see if a E rated tire is what your after. Plies count and not all E rated tires are created equal.
I vote this the most ambiguous and misleading pole in t4r history. LOL:faint:
Hey, I was just trying to keep it as short and sweet as possible like that slew of 1engineer polls a while back. :hello:
I could've said "Have you ever had a tire puncture or cut while driving in 4L on moderate trails comprised of clay or clay-loam soil and smooth rocks indigenous to the Southeastern United States, while driving on P-metric tires in a situation that would potentially not have punctured or cut a LT tire?" But that seems a bit wordy. :nerd:
Tire information here and everywhere is all over the map in terms of "common knowledge" (anything less than an E-rated MT is dangerous, or KO2s are only for looks and stock is fine) so I was trying to get some data points on field experience.
Currently the poll shows a 20% rate of failure (if you can call it that) for P-metric tires off road. That's much higher than I expected as I tend to think a lot of upgrades are for the fashion statement rather than actual usefulness. In this case these flaky, unscientific statistics point to off-road-focused LT tires being a potentially solid choice.
I've been riding on my P-metric Michelin LTX AT2s this winter and loving them on the highway. I don't like riding in mud and with the short days I don't get out much. However in the summer my wife and I really enjoy taking the dog for "adventure" rides up through the NE Georgia mountains. That means light to moderate trails with lots of big gravel and rocks. I'm thinking I may want to get a set of some kind of off-road-focusedLT tire for this summer.
There's a lot of factors that go into a tire's rating and it's durability offroad. In the end it tends to be a spectrum from very good highway tire to very good offroad tire. The strongest offroad tires are bias ply. They suck on the highway. On my trail rig I have bias ply super swampers. They're great off road - and horrible on the road - very tough sidewalls.
For radial tires - the strands of fiber that run from bead to bead making up the strength of the sidewalls are radial. They all run parallel around the tire. The result is that they are inherently a lot easier to puncture than a bias ply tire. The higher load rated tires will typically have thicker sidewall rubber typically and more strands of nylon or polyester fibers. The benefit is higher pressure capability and higher load rating. For us that tends to mean a bit more sidewall protection from punctures or cuts. Being radial construction - a sharp rock will go through any of them. Nylon or polyester fibers just aren't all that resistant to sharp objects. The thicker rubber is what makes the difference primarily. The downside is that the sidewalls are thicker so low pressure means more heat buildup and faster deterioration of the sidewalls. Thick sidewalls tend to break down if used frequently at low pressure and require lower pressure for similar contact area. This also has to do with the individual tire. Some E rated tires are thicker than others. There's no reason that an E rated tire *must* have thicker sidewalls than a P-metric tire.
The biggest problem is that we're using a load rating as an indication of a tire's durability in a non-load context. Is the string longer than the rock is heavy? So there's really no direct relationship - although the higher load rating *tends* to correlate closely with sidewall rubber thickness and resistance to puncture/cuts. So there are also the tire specific stuff like kevlar in the sidewalls and/or tread areas. A kevlar/aramid reinforced sidewall is probably more puncture resistant in a p-metric than a non-kevlar tire with an E-rated load capacity. Aramid/kevlar fiber is very resistant to cuts and abrasion. Far more than nylon or polyester. Probably like in the order of 100's of times more resistant to cuts. A thin layer of aramid fabric would be better than many layers polyester. Similarly the rubber compound makes a big difference. Some rubber compounds are a lot more resistant to punctures and cuts than others.
Typically dedicated offroad tires tend to have more durable sidewalls whether they're LT rated or flotation sizes that are basically P-rated most of the time on the scale of pressure/load capacity.
And the difference between a Pmetric and C rated designation probably has more to do with the mold and rubber used than with the casing construction. Generally LT tires have non-silica tread compounds with deeper tread and P rated tires have less tread depth but use high silica rubber that's more wear resistant.
Ultimately I think the choice in what's best for each person is going to be situational. What is pretty well undisputed is that there's no reason to ever have an LT tire RATING because the 4runner cannot carry loads that would necessitate the LT tire capacity. The sidewall thickness and other things may make them worthwhile.
I was just being a bit of a jerk/ball buster..
The most ambiguous term in the poll is blow out.. Most people associate that with a sudden and catastrophic failure of the tire. I think what you were after.. was if people had experienced tire damage or loss of pressure while off-roading a P.
Then there is the obvious difference in terrain, since off-roading means so many different things to so many different people.
Finally, even within terrain, people get mixed up between well traveled established (sustainable) trails vs rough constantly changing wash outs... Difficulty of the trail does not necessarily correlate with tire damage potential (although there is some correlation) Even though a place like Moab can be very hard on tires, it can also be done on just about any tire with no issue because of the underlying terrain and how established the routes are. So an easy summer only gultch trail in CO can be 100x harder on tires than a difficult trail in Moab.
All tires will eventually see damage if you push them hard and often enough. The only one ones I have found to be bullet proof are bias plys. And I seriously doubt any sane person with a 5th gen wants to run them.
I don't think any P tire could last me more than one off-road trip unless I completely changed my entire approach and constantly worried about my sidewalls. Would be a fun exercise to try though....I've seen too many Ps let go on very mild terrain, to even consider them for overlanding.
I may have forgotten but thinking back, I have had 5 flat tires on 4 different vehicles in the last 25 years. All have been on OEM P rated tires. I have never had a flat on a LT tire.
I do believe aftermarket tires are usually better than what comes from factory and top quality P rated are decent but still I won't run less than C rated on anything that goes off highway.
Didn't vote.
Just to add a bit of real world trips - so far on the current P rated tires on my 4runner I've done Hell's revenge a number of times, poison spider mesa, white rim trail twice, fins and things, Gemini bridges, elephant hill, monument valley with a camp trailer, lots of trails you've never heard of in Montana, towed a camper all over the western USA for probably 3,000 miles. I've had one flat. I don't much like the tires themselves (Toyo AT2), but I'm not convinced p rated tires are problematic. Are they ideal for sharp rocky trails? no. But the idea that they have no business in the dirt is pretty silly.
Come on up my way. I'll change your experience. :bounce:
I did some light off roading in my stock Yokohamas on my 20" rims. Did some beginner trails here by Austin and drove a few of the unmaintained roads in Big Bend. I didn't have an issue but I took it slow and drove carefully.
In Big Bend, I also stopped and helped a pickup that DID have a blowout on P rated tires. Didn't have equipment to change a flat out there either but that's another story.
Can't wait to take the new BFGs out now.
I've done top of the world (Moab) on my weak sidewall P rated coopers aired down to 25 psi and other rocky trails around Colorado aired up. Not one problem.
Well, I should have posted my P 265 70 17 Wildpeaks report here.
I find it hard to believe that there is anything in Oregon that would make a P Wildpeak flinch. Montana and Utah are not an issue. Southern AZ is the one place that gives me trouble and may ultimately force me away from P.
The confusion arises from mixing all P metric tires together. Only ATs count. Beyond that I want massive shoulder protectors.
In terms of actual plies, everyone here knows the tires with a 3-ply sidewall. More interesting is the tread situation. The tread of a SL P-metric, even the Wildpeak has 5 plies as do some LTCs like the Cooper AT3. XL P-metric like my Nitto 420S on the Subaru and some LTCs have 6 plies in the tread. My LTD KO2 had 6 plies in the tread also. LTE Toyo AT II, however, has a whopping 8 plies in the tread including 3 steel.
According to BFG, there is a direct correlation between ply number and puncture resistance. According to Falken, there is no offroad puncture resistance difference between their P and LTC even with a 10lb extra weight on the LTC (275LTC vs 265P). According to Toyo, if you run a lot of offroad terrain, the usual longevity patterns inverse and an LT has a chance to outlast a P. They actually recommended I get a commercial grade AT when I described my use, lol.
Finally, in my experience P tires need to be run at 28 psi or up except for deep soft stuff. I climbed Kamikaze in Utah with 36 psi in the rear tires (because I forgot). That won't work with an LTE. So a P wins in the convenience department as there is no airing down and up. However, an LTE at 20 will be more comfortable than a P at 30 over rough terrain, especially with capable shocks. But the relation between tire choice and suspension choice is another story.
Anyway, it is indeed silly to claim that a good P metric cannot do lots of offroad. I have about 5,500 off pavement miles on Ps in the SW and MT with one puncture (tire fault of the P but an LTC may have fared no better) and one sidewall burst (I think I caused that by airing down). These include Wildpeaks, Toyo AT II, and Geolander ATS.
Helpful poll. Apologies for the necropost. I have a 2023 TRD ORP arriving next month and I won't want to be on the stock all-season tires for long. I have spent way too much time going down the P-metric vs. LT rabbithole. I am going with A/T tires.
I think I may indeed go P-metric, and I go offroading several times a year, mostly in Utah/Colorado deserts and mountains. I do value on-road drivability, and I'm leaning away from the LT E Range club. I've seen some people claim they'll only buy E-range LTs, even on lighter vehicles like 4Runners, and claim that you'll just pop P-metrics the second the pavement ends. It's my understanding that E-range tires are mainly to support large weights, yet people often claim they're exclusively buying them in relatively light vehicles for extra offroad sidewall puncture protection. I've found a thread where a Falken rep claimed the Wildpeak had identical sidewall protection in all varieties, from SL to E. Meanwhile, in my own experience, I took my '99 4Runner on half of Hell's Revenge on P-metric all-seasons, among several other trails, with no result. As far as my own uses, moderately rocky trails can happen, I err on the side of slow and careful, I avoid tree roots and other dangers, and in 11 on-and-off years I have never had an offroad tire failure, regardless of tire type. If I recall correctly, the TRD PRO model even comes on P-metric tires.
Load Range C LTs almost started looking like a solid middle ground (on the few A/T tires that offer them in factory size). Someone pointed out that BFG KO2's in Load C are load index 112--which is actually lower than the load index 113 A/S's the 4Runner comes on.
Wildpeak AT3W's, Open Country ATIII's, and the venerable KO2 seem like the best options available to me. Some offered P-metric SL, some LT Load C's, all offered in an LT Load E as well.
Given how many 5th gens are sold and offroaded, I feel like I'm the 100,000th person to have gone down this path of excessive research and overthinking!
tyler_ross
