Infinity Kappa 32.9 cf substitute
JamesWhite
I ordered Infinity Kappa 32.9 cf for $70 from SonicElectronix for the phase 1 of my car audio project. I was told today they are out of stock. I can get it from amazon for $100 including shipping. Before I spend almost doubled price for the same thing (2 years ago), I wonder:
1. If any other brand will have similar result and price.
2. What about Polk Audio DXi350 3-1/2" 2-way car speakers?
3. What about to use componet set on dash and front door?
Thanks for your help!
James
Was wondering the same thing. Went to find some kappa 32.9cfs to install when I had time and couldn't find many reputable retailers.
I installed the REF-3002cfx instead of the 32.9cf. I actually went Infinity reference X series all around for me, thought if you are willing to spend that much already, why not spend a little more and get better yet.
Infinity REF-3002cfx 3-1/2" 2-Way Reference X Coaxial Car Speakers
I am absolutely a layman and this is the first time I ever try to DIY audio system. Are the following specs telling us the Infinity REF-3002cfx is better?
I notice the power handling, lower is good or bad? I am just curious and try to understand more. Thanks!
•3-1/2" Reference X Series 2-Way Car Speakers
•Power Handling:
◦Peak: 150 watts per pair / 75 watts each
◦RMS: 50 watts per pair / 25 watts each
•Polypropylene cone material
•Plus One woofer cone technology maximizes cone surface area
•Butyl Rubber speaker surround
•1" edge-driven Textile Dome tweeter
•Adjustable tweeter level attenuation
•UniPivot tweeters allow you to direct the sound
•High-temperature voice coil design
•Ferrite magnet motor structure is vented for fast cooling
•3 ohms impedance works with all amps rated for 4-ohm operation
•True 4 ohm technology incorporates speaker impedance with factory speaker wire impedance for maximum power
•Frequency response: 85-21,000 Hz
•Top-mount depth: 1-7/16"
•Sensitivity: 91dB
Infinity Kappa 32.9cf
•3-1/2" Kappa Series Car Speakers
•Power Handling:
◦Peak: 210 watts per pair / 105 watts each
◦RMS: 70 watts per pair / 35 watts each
•Woven glass fiber cone woofer
•Rubber surround
•1" Edge-driven MMD (Metal Matrix Diaphragm) dome tweeter
•Computer optimized voice-matched passive crossovers with audiophile-grade air core inductors and polypropylene capacitors
•Adjustable tweeter level (-3 dB, 0, +3 dB)
•2 ohms impedance
•Top-mount depth: 1-5/8"
Check the sensitivity - you want the numbers to be similar or same...
Otherwise your dash speakers might be way too quiet at the same volume to mesh with the rest of the system.
Kappa is actually a higher level series then Reference. Also, they are less sensitive than the stocks so they will play softer. Depending on what stereo you have, effect varies.
I have already had both, so when it came to the 4R I already knew which of the two I was going to use. I had the 32.9cf's in my FJ and the REF-3002cfx in my Tundra, my ears were the judge. Get whatever makes you feel better though...
The higher the power handling, the more they require an aftermarket amp to power them. A speaker with lower power handling will work better with the stock system. However if you are adding amps, match them to the speakers (alittle overpowering is OK and typically sounds great)
bluelinepilot
