Info on buying Tundra Coils
256 4Runner
Hey y'all I'm about to buy some tundra coils and just going to get some information figured out and make sure it's out there for others to use as well.
We all know the Tundra coils need the yellow/yellow yellow/blue markings and the following numbers(taken from the lift thread):
Driver side - 48131-AF100 Yellow/Yellow
Passenger side - 48131-AF090 Yellow/Blue
Someone on here has found this place for the cheapest price online: Toyota Part Sales of Toyota of Dallas
Direct Link: Toyota Parts - Toyota Part Sales of Toyota of Dallas
There are three pages each for driver and passenger coils matching the part numbers. The coils range from SR5 to limited to base and so on. I was unsure if the part numbers were the specific color codes needed or if there were sub sections of the part numbers (ie. part number -> color code) as it appears in the lift FAQ. So I emailed them and this is their response:
"Each part number has a specific color code.
There are not multiple color code for a specific part number.
Best Regards,
John Teckley
Toyota of Dallas- Internet Parts"
So what I want to know is, is that correct? Can I just pick any coil from the three pages and have the correct color codes?
while we are on the subject of different trucks using the same springs, I seem to have found a local set from a from a 2007 tundra; the seller states that one has a yellow and one has a blue dot, would these be cross compatible as well or only the 00-04 models?
You don't want coils from a 2007, they will be too big. You want 2000-2006 year range.
