OMG... What an ordeal this was.
Things I learned in the process:
If you decide to do this, get a second set of headlights before you begin. You might screw things up and/or it might take a long time to finish the job. Also, having a second car helps.
If you do get a second set of headlights and you decide to get a cheap set off eBay, know that you're getting what you pay for. BTW - I set my factory units aside and hacked the eBay lights, mainly because when used with halogen bulbs, the eBay lights throw off a pretty lousy light pattern which I knew would become irrelevant once the projectors are installed.
Be careful with JB Weld. I don't think I'm capable of wielding that kind of adhesive power without adult supervision. I used it to permanently set the projectors in place in the reflector bowls and I now regret it. I made things much harder on myself. Even though I did my best to align the lamps horizontally before I glued 'em, once mounted on the truck they're slightly off and the light being projected has jagged edges and a "hot spot" that's annoying.
This being said, the amount of light being thrown off is insane. 35W, 4300K.
