Installing TRD Pro bumper trim pieces on SR5
Well, I now have a spare classic silver handle panel with emblem and letters dipped black.
Let me know if you're serious, I'm sure we could figure something out.
I'm accumulating a lot of parts in the garage, guess I'll have to jump into one of the 'For Sale' threads soon.
Do you have the rear hatch panel up for sale?
I'm actually going to start building a Silver TRD Pro w/KDSS... lol..
Changed my mind from a Trail to the Trail Premium. Will have the Pro rims installed at the dealership before I pick up. I do like the PRO grill a lot, so grabbed that... Ordered some 275 KO2s...
Just need to decide if I/m gonna spend the change on the bumpers, or just plasti-dip.. Bam... TRD Pro w/KDSS..
I am looking into wrap the front valance and the back instead of the chep plastic dip:embarassed:
Yip. Thats what I did to mine. Added a bunch of Pro window dressing and now moving on to other things ... :)
I took some pics of mine and a few trails up at the dealership for reference, and I noticed each pic was different. Mine isn't 'perfect', but neither were the referenced pics. My .02
Just line up the letters/emblem nipples with the hole-like things one at a time. Take your time. Look at your reference pictures. Patience. 'WoooooSaahhhhhh'
\m/
Can you tell me the parts number for the TRD front and rear valance black and clips. I might have to order them instead of vinly wrap mind. Might cost me less and would look better. Thanks in advance :peace::usa2:
Has anyone tried converting from SR5 to Limited
Has anyone tried the reverse of this thread? Looking to swap the SR5 front end (bumper, grill, etc) to that of the Limited.
Like the Limited look better and would like to put that on my 2016 SR5.
Im assuming its all direct fit. Probably just buy the limited bumper and bolts right up...
I use those part diagrams and check surrounding parts (splash guard, wheel well inserts) make sure those part numbers are the same between an sr5 and limited.
BTW where in wisco?
BTW where in wisco?
You would need to swap the fender liners, crash beam and other small parts to make the Limited parts work on a non Limited. Its not a direct swap.
Step 1: Acquire TRD Pro Parts
Step 2: Take off front bumper
Step 3: Use dremel to create slots. There are 13 indication marks on the bumper.
Not the finest craftsmanship.
Step 4: Install front valance panel to bumper using clips
Step 5: Put back front bumper
Pretty Easy! Hardest part was taking off the front bumper.
Im looking for Black TE or PRO roof rack ends caps if anyone is selling them or wants to trade for silver ones off an SR5.
:welcome:
Awesome!
Can this be done to a trail?
i've had some questions on the trail to TRD rear valence swap i helped my friend with, so i thought i would post some pages from the repair manual (found somewhere in this forum) and the basic steps in this appropriately titled thread to help those searching:
1) remove rear mudflap screws and snap rivet things (not sure what they're called) there's about 6 total on each side) and take mudflaps off
2) remove 6-8 screws/bolts from underside of bumper cover
3) open tailgate and remove jack box hole cover
4) remove 8 screws/bolts that were hidden by tailgate (6 around bottom & 2 up sides)
5) wiggle the bumper cover loose starting from the edges at the fenders working toward the center of the tailgate opening (comes off with minimal effort once bolts r gone)
6) undo the clips hold the valence on with a flat head, slap the new one in and reverse the steps to reassemble.
notes: all the above mentioned screw/bolt heads are 10mm & keep an old blanket on the ground to lay the cover on once its off. it weighs next to nothing and this can certainly be done solo, but having a partner never hurts.
Wow, I think that's the first I've ever heard. I think the Limited front end is absolutely hideous, but to each his own I guess.
Rear bumper valance part number and clips
53901-35250 Front TRDP bumper valance - $159.26
7539235220 Bumper valance clips (13@$1.34) - $17.42
63491-35030 + 63492-35030 TRDP roof rack Front end caps (black) - $38.55 per
63493-35030 + 63494-35030 TRDP roof rack Rear end caps (black) - $39.86 per
7681135220 TRDP rear lift gate handle panel (black) - $115.16
7543135050 New rear nameplate (4RUNNER) - $43.75
7543206030 New rear Toyota emblem - $12.14
7681935010 Back Door Outside Garnish Seal
You can find great pricing at the sites below:
Toyota Online Parts | toyotaonlineparts.com | OEM Toyota Parts
AutoNation Toyota Gulf Freeway Parts - Genuine OEM Toyota Scion Auto Parts and Accessories - Houston, TX
Find Toyota Parts at Discount Toyota Parts - AutoNation Toyota South Austin
Hi,
I'm about to purchase a White T4R Trail and just came across this forum. I really appreciate all the great info!!
I'm looking to replace the front and back valances with the TRDPro black valances. I have the part number (thanks to Hook Em' Horns) for the front valance, but need the part number for the rear valance. Does anyone have that??
I also saw the clip information on this forum. If I use the clips that come with the White Trail, will they show on the black valance? or should I order the black TRD Pro clips?
