KodeRush
Thanks! I just couldn't connect these two phrases together.Body Mount Chop
Thanks man. My current caster is 3.0, so I should probably redo the alignment before I start chopping the body?Get the angle grinder and hammer ready. You'll probably need to cut your body mounts entirely and hammer back your pinch welds. Not sure what kind of modification you'll need to do to the fender liners since I don't have those. You'll probably also need your caster set as close to +4 as you can get.
These went in like butter today. Just need to get an alignment then find out how they are on the trail.
how do you like your UCAS? and how much total lift do you have I was looking through your build and didn't see if you did a body lift but it didn't look like it, love all your snow wheeling pics very little snow wheeling in nor calSo I shouldn't mention that the place where those pics were taken is only a half hour drive from Calgary? I'm headed back there after work with a couple buddies to do a short trail run then should be home before it even gets too dark![]()
I haven't even had the new UCAs in for 24 hours yet but everything feels good so far. I've got somewhere around 2.5" of lift and no body lift. Don't think I would ever do a body lift either.how do you like your UCAS? and how much total lift do you have I was looking through your build and didn't see if you did a body lift but it didn't look like it, love all your snow wheeling pics very little snow wheeling in nor calrocks for days though
I'd love to do the Rubicon but I don't know if it's in the cards. Pretty long drive from where I am to begin with. Maybe after I go long travel I'll consider making the trek.would love to see your 5th gen TE attempt to tackle the Rubicon Trail from loon lake to buck island, that would be an awesome run been up there a ton of times never seen a 5th Gen up there and only one other 4th gen. tons of purpose built trail rigs do not make it without breaking, I was with a hemi swapped jk unlimited on 37s and he broke
I need to replace the bushings, and possibly the uniball this spring.
Is there a recommended mileage change on the uniballs?
Hah, thanks for the kind words everyone.
Latest mod is in, a North Star deep cycle battery to handle the power draw from the winch. The extra wires are for the winch and the wiring harness for the X-Ray lights.
Yup, a Blue Sea block is on my shortlist of mods.One suggestion would be to use an electrical distribution bar (busbar) for your wiring needs.
