Inv4drZm's Build Thread
Test welded some 1/4" 6061 aluminum, which in some ways is stronger than 3/16" steel. Mig welder didn't do so great but tig was much better. Could make my bumper or buddy's Tundra bumper out of the stuff I think. Welder is maxed out at 200 amps. 6061 is stronger that 5052 that normal aluminum bumpers are made from but the sheets can't be bent, it would crack.
Backside hints of penetration to the right of the tack weld.
Replaced the starter in my 4.7 Tundra after it sitting over the winter. Harder than I anticipated due to the air injection system the 05+ Tundra's have. Had to reach my hand between the engine and the firewall for 2 long bolts, not fun.
Buffed all my headlights too, and fixed a skid plate/exhaust rattle under the 4Runner. Noticed a CV boot clamp came undone and messed up the finish on my King coilover.
Getting close on my 2014+ Tundra bumper design for my buddy's truck.
the starter is the one thing I hope stays alive until I'm ready for an extensive rebuild (or swap).. I don't have the secondary air injection, but having to do any work on this thing sitting as high as it does, and having the coastal bumper, is an absolute nightmare.. I would very much prefer to just yank the motor out and then work everything on a stand.. (or just drop an LS into it :banana: )
I was this close to buying or building a topside creeper. Would have prevented me from stepping on the coolant temperature sensor and having to replace it lol. Either that or unbolt the motor and slide it forward a few inches would have helped too.
The 2UZ starter is no joke. At 6'6", I have an advantage, but I still had to lay down on the fender and core support with my feet off the ground.
Pondering the best way to add cats to my long tube headers without losing rock clearance, and quiet my exhaust. Tired of the fumes and noise.
I'm pretty sure the only way is to add the cats after the X pipe, though I'm not sure how efficient they will be that far from the headers.
The other option is going back to a single muffler setup (removing my X pipe), and adding a cat after a Y pipe. This would reduce muffler weight and increase rock clearance and I could run my oem tailpipe to move the exhaust fumes out.
All 92 pages (so far) of this thread are incredible - thank you for sharing so much with us! You've given me a lot of ideas and added many things to my shopping list lol
Swapped rear diff cover to a stronger one that hopefully doesn't leak, replaced front, mid, and rear diff fluids. And did engine oil changes in both trucks.
Lucas 85w-140 in front and rear, lucas 75-90 in center diff, mobil 1 in engines.
5 gallon bucket fit great under the 4runner in all but the rear diff lol.
Picked up a new torque wrench from Harbor Freight after getting tired of the cheap old torque wrench from Harbor Freight not clicking strong enough for me to feel.
For my future reference, existing mangled skids weigh:
Front: 42.5
Mid: 35
Rear: 30
Total: 107.5
Hoping to make some lighter ones out of 1/8" AR.
Took 3 days off for my birthday and to catchup on the Celica and 4Runner project list.
Something I didn't take pics of, I added .25" fender washers to my 1.5" body lift so my rear doors don't contact my bent sliders. I'll work on beefing up the rear of the sliders later. For now this was an easier fix than cutting off the sliders and rewelding.
I beefed up the passenger side front diff mount with some 1/4" AR plate.
Replaced my stock style one-way rear diff breather with an ARB breather which is 2-way.
Welded the edges of my aluminum switch pro water and dust shield. I made this cover years ago but never got around to welding it. Wasn't really necessary but looks better and seals better.
Might start selling these for 4Runners, made from 1/8" aluminum. Uses factory tie-down points to keep cost and installation time down, as well as easy removal. Can bolt to a plywood base though if you want to make one. Can run either module separately or together, and each side can mount a molle or blank panel for an air compressor and tank setup. If you want 4 drawers or 2 fridges (lol), go for it. I've kept the height minimal so it won't impede rearward visibility at all, but plan to make a taller set that incorporates another drawer on both sides.
Been looking online at newer trucks, not super seriously, but have considered just about anything new between a 2022 Tundra, single cab 5.0 F150, or even a Silverado trail boss as a DD and expo rig. I don't put many miles on so decided I wanted another gas guzzling V8 lol.
Then the perfect truck popped up for sale at a local dealership. 2019 Tundra, extended cab, 6.5ft bed, white, color matched bumpers, already leveled on 33's, already has cool wheels. Only 13k miles. Fell in love and drove it home!
"The last of the V8's" still rings true lol
Super nice upgrade over my 2005 trucks.
Are you going to keep the 6.5 ft bed or are you gonna shorten it? I've seen some cool extended cab 2.5 gen tundra builds from a few shops. the shorter bed looks cool. Except less functional...
I considered a Raptor in that configuration but decided a 6.5ft bed will be nicer when I actually need a bed and I can still sleep in the back of the truck if needed.
In Kansas a longer bed/wheelbase won't be noticed unless parking in bigger cities. In Colorado I only plan to do milder trails with this so a foot shorter wheelbase shouldnt be an issue.
I eventually want Decked drawers, and possibly a mild single exhaust system, I might weld it myself. I like the stock shock's ride on concrete and may not change them out but a budget Fox 2.0 setup is being considered. It already has 1 size bigger tires than a TRD Pro, any bigger and I may need to remove mudflaps which I don't want to do.
Are you talking about crew cab builds with the short box or an actual double cab with a shortened frame/5.5' box build? The latter I would like to see...
SDHQ has built a few trucks like this, they used to have a decent build gallery but looks like they only have newer trucks on it now. Older Silverados and Ford Raptors are offered in this config from the factory. I like the idea of the shorter wheelbase but my 13k mile truck is just too nice to chop up.
R.96d21cccfc5a09a7ac33f004ec888d7a
07-20-toyota-tundra-sdhq-built-in-bed-chase-rack-chase-rack-sdhq-off-road-116237_1024x1024.jpg
Yes, your truck is much too nice to shorten the frame on! My 08' DC is a POS with approx 280k miles. I'd like a shorter truck and my box has a lot of rust holes from the crap plastic liner that was in it. I'd like to do a 2.5 gen swap on it (with the shorter 5.5' box) but I'm not sure it'd be worth it in the end. I doubt in this current market my rusty heap is worth over 10k CAD.
I totally agree with your resolution. If I had the knowhow I would want to do a shorten'ed wheelbase DC 2.5 gen tundra. I love the 5.7 in our land cruiser. I just want to do truck things that the SUV can't do.
How it looks now:
Prologue:
My family owns a small herd of Toyota's. The vehicle I grew up riding in was a 2nd Gen 4Runner, and my parents currently have a 14' Tundra and 03' Sequoia, while my twin brother has a voodoo blue 07' FJ with Icon Stage 1 & full armor he recently inherited for a steal from my parents. He and I drove the FJ to high school on occasion but mainly a 00' Dodge 1500.
Now he and I go to the same college, but were starting to need separate vehicles. I've always been extremely interested in cars, so it was an easy decision for me to decide on which one, right? It had to be one I could mod and daily drive dirt roads/snow. Researching consisted of watching Autotrader/Cars.com/Craigslist incessantly every day. I first started by looking at some WS6 Firebirds. But 2wd would suck in the snow. Then to Suburu WRX's. They look cool, make boost noises and are AWD, but reliability didn't seem the best as most looked modded/raced/rebuilt. Lexus has a nice looking 4dr IS350 with 306 hp I test drove and almost bought, but I live on 2 miles of dirt roads; it seemed way too nice for me! After making spreadsheets with mod lists for just about every vehicle in my budget for sale within a 250mi radius, including M3's, SVT Lightnings, TrailBlazer SS's, GTO's, RX-7's, MazdaSpeed3/6's, Evo's, 240SX's I was thoroughly confused!(And so were my parents!) How does this explain the picture in your lower peripheral vision, you ask?
Back in highschool, I thought a 4th gen 4Runner looked pretty hot for an SUV. (Better than the FJ! ) Especially lifted ones I saw on these forums. Why didn't I consider these earlier? They checked all my boxes except the go-fast, irresponsible, drift machine box:cry2:. Narrowing my search to low mileage 4th gen V8's and 3rd gens, they all had numerous door dings and scratches/other issues. I looked obsessively for a whole summer, and finally a nice craigslist ad popped up by owner for a 2005 4Runner Sport Natural White V8 with 115,000mi at a decent price too. But it was almost 4hrs away in Oklahoma. My dad and I called the owner and talked, and drove down the next day to finalize the deal. The 4Runner didn't have a spec of dirt underneath, but had a few more paint dings than I had anticipated, although still in the best condition I had seen in my search.(I'm way to picky apparently!!)
I ended up driving 4hrs home as a happy new 4Runner owner with big plans and an even more broke college-student-budget!
Hopping in to go home; I'm overly-enthusiastic for a long drive!
Fast forward a couple months, and I've decided I should start the "Build Thread" with goals to record my progress and hopefully take pictures of it out in the wild. I'm really not certain what path to take with this build, but hopefully I can help others mod their vehicles on my way. My two dream cars would be a long travel 5.7L swapped speedway blue Taco :crazy: or a Supra :hail:. The 4Runner will just have to hold me over until I can afford one or both. But it should be a pretty sweet ride up until that point! Stay tuned!
Current Mod List
Performance:
Dirty Deeds 20" SS Exhaust
Doug Thorley Long Tube Headers
Homemade 2.5" Equal Length X Pipe
Homemade 2.5" Magnaflow Dual Muffler Section
HCF Delete
AFE Drop-in Filter
AFE CAI
Sprint Booster
Functional Hood Scoop
Rear Spoiler Added
Stoptech Cryo Rotors
Stoptech Pads
Drivetrain:
ECGS Dana 60 Rear Axle +6" Width 4.88 Gears ARB Locker
Front ARB Locker
Custom Machined High-angle CV Cups
Comms:
Cobra Hand-held CB Radio
2ft Firestik
Diamond K400 Hatch Mount
Suspension:
Camburg 1.25" Uniball UCA
Icon 2.5" RR+CDC Coilovers w/ 700# Coils
Wheeler's Front SuperBumps
Total Chaos +2" Standard LT Kit w/ Heim UCA
King 2.5" RR+CDC Coilovers w/ 600# Coils
Bajakits CV Axles
Taco Tab Alignment Cam Delete Kit
Wheeler's Diff Drop
Icon 2.5" RR Rear
Metaltech HD Long Travel Rear Coils
Wheeler's Rear SuperBumps
Front Range Offroad Upper/Lower Links
4Crawler 1.5" BL
Wheels/Tires
315/70R17 Hankook Dynapro MT
37" BFG KM3
SCS 17" SR8 Matte Dark Bronze
Armor:
Homemade Front Bumper w/ Warn Evo 10-S Winch
Modified DIY 4x4Labs Rear Bumper Kit
RCI Front Skid
Homemade Transmission, T-case, Fuel Skids
Stubb's HD-SKO Sliders
All Pro Lower Link Skid
TC Spindle Gussets (not installed)
Relentless Fab BMC Plate (not installed)
Ceramic Coated Paint
Homemade Aluminum Inner Fender Liners
Other:
Poly Bushing Rebuilt Front Control Arms
Full Sound Deadening
Desert Does It Seat Jackers
Indel-B 31L Fridge
Switch-Pros Panel
Sparky Gauge Cluster White LED Conversion
XPEL Protected Gauge Cluster Lens
Diode Dynamics Interior LEDs
Cheap LED Pods and Bar In Bumper
LED Headlight Projectors, 06' Conversion.
Rocksteady Motorsports Windshield Washer Tank
Factory Roof Rack Delete
ARB Dual Compressor System
Homemade Aluminum Drawer System
FJ Fender Liner Conversion
Shopping List
PSC Steering Fluid Reservoir
Marlin LT
Rear King 14" Coilovers
Long-Term:
Seats
Boost
Crawlbox/T-Case
Relocate Fuel Tank
Double-triangulated 4-link rear suspension
Internal Roll Cage/Bar
I Am interested in the long travel file you made for your 4th gen. Can you dm me on instagram [MENTION=714644]4.wunna[/MENTION] im not really on here.
tuṣṭāva
