Is KDSS worth the cost????
I'm screwed! No antenna on mine! Since kdss leans right and my sr5 leans left maybe I will add half of the kdss system and it should even out.
You just never let your gas get below 3/4 of a tank if you have KDSS.
Seriously... I would of got KDSS if could of found a silver Trail that was not located on Jupiter!
However, after installing about $4K worth of suspension, KDSS is just a distant memory to me.
I tell ya what I'm frustrated with: I can't even find the button to turn my KDSS on and off. I paid all this money for it and they forgot to put the button in.
It's on your multi-terrain select, that controls your KDSS. :tape2:
I believe that was my first ignorant assumption when joining the forum, had many more since. :doh:
you have to add a stubby antenna to offset the lean... of and you can run 40s easily if you do a bodymount chop
Is there a specific location I should put the stubby antenna so it evens out the lean fore and aft also?
Does it need to be connected to the radio?
Do I need a specific brand of stubby antenna?
Does my CB antenna mounted on the passenger side of the roof help with the lean?
Do I need to do a body mount chop since I'm in my 50's (don't answer that)?
What brand/tread/model of 265/70-17 tire will actually fit my wheels?
What does KDSS have to do with the function of the stubby antenna, much less running 40s, which I haven't run since high school football? When I was actually pretty fast. :naughty:
I really wish you noobs would use the damn search function!!!!!!
It's the big red button by your steering wheel that says Start. If you don't have that button you don't have KDSS.
Button? everyone knows to engage KDSS you maintain 75mph, throw thow the transfer case into 4lo, lock the axles and turn as right as sharp as possible!
Can I start a new thread just to say I had a dream about trading in my 14' 4Runner for a 15' 4Runner?
Please tell me yes, and if I do will it affect nose dive or driver's side lean?
:typing:
:typing:
Next thread title:
"POLL: DO YOU GUYS THINK FARTING IN YOUR 4RUNNER IS BAD?"
YES
NO
