is the Venture lower on the front end ?
Gouranga
than other models ? i know the pro is an inch higher at the front than the venture but what about the other models ?
mostly asking because i got a 2021 venture and i always gets flashed at night as if im driving with my high beams on but im not.
so i was thinking maybe they messed up with the angle of the headlights and didnt adjust them to match the lower front end than other models if that makes sense
say someone from the dealership has to adjust the headlight tilt angle higher because the front end is lower but they over did it which explains why im blinding people at night when driving or is that not it and its just the way the headlights led's are ?
headlights should be aimed properly from the factory. you either have a lift, put LEDs or did some other work around the headlights and messed something up. you can reaim them yourself it isn't too hard
The factory LEDs have been known for being aimed a tad high from the factory. Plenty of posts about being flashed by oncoming drivers.
They just need to be aimed down a bit.
adjusting headlights 4runner - YouTube
Your T4R is no lower than any other T4R.
You answered your own question, when you stated the pro is an inch taller.
There is no guarantee that the factory aims headlights correctly. Height or to each other …..
Back off 25’ from a wall on a flat surface. Measure ground to headlight on T4R, transfer measurements to wall minus 2 - 2 1/2”. Adjust headlights to that.
Easy peazy
i noticed when i got my new 4runner, the headlight angle is quite parallel to the ground. i had to adjust the aim down to stop blinding other drivers and enough for me to see 200 feet and use my auto high beam if i need to see further.
I have a 21 Venture and re-aimed the headlights after multiple vehicles flashed me. Havent been flashed since.
Flash them back with your lp9s:)
Anything mass produced can’t be perfect. That’s why there’s always limits to pass quality control. Just aim them yourself. Toyota made it super simple and accessible.
tssawlson538
