is there a way to tell if my timing belt has been replaced
save_alkaline
i bought my truck used and just got to thinking about the timing belt. is there any way i can tell if it has been replaced recently? the service book has no records.
Do you have a V6 or V8?
V6 has a timing chain
V8 has a timing belt
You could try calling the local dealer and see if they have any records based on the VIN.
My 2002 is a V6 and has a timing belt. I think when they change it, they mark the date changed on there somewhere, at least my dealership did when I just had it changed.
You are right the 3rd gen 4runners had a timing belt in the V6. Being that he posted his question in the 4th gen forum, I assume he has a 4th gen.
I noticed that but wasn't sure if they went to a chain on the 4 gen if it was a V6. But I guess now we know, he has a V8, which would be a chain, I guess, ....
I just changed my belt myself with a new toyota belt. In the bag with the belt there is a sticker you write the mileage and date on and stick it in the timing belt top cover. It has a plastic protective cover that goes over the sticker. The sticker is aprox 3/4" x 3".
That is what it was that I saw on there after the did the change, a sticker with the date and mileage marked on it.
I'm saving my sticker(s) for a rainy day. Just in case if i ever sell my rig, i'mma backdate or post date it before i stick it on. lol
The V6 has a chain
The V8 a belt.
Can someone explain why one has the chain and the other a belt?
Thanks.
Rob
My only guess, it's a newer engine. The V6 was introduced in 2003 with the 4th gen's debut. The 4.7 V8's been around since 1998. However, the new 5.7 V8 is also a belt. Only Toyota would truly know.
cool. i'll poke around and see what i can find. thanks for the info!
One important thing to remember, is that your engine is a interference engine. If it breaks, damage can happen to the engine, the valves could bend. So, if you are over 90,000 miles, you are living on borrowed time. Someone reported here buying a V8 with 120,000 miles and it was not replaced. So, it could last for awhile or it may not. As Clint Eastwood would say "Do you feel lucky punk, well do you???"
ah.. more good info. i was curious as to whether it was an interference engine or not. i definitely plan on getting it done ASAP if i find that it's not been done already. here's to hoping it has been though.
this might sound dumb.. but... umm.. where might that cover be located? :confused:
i'm not used to these toyota engines.
The timing belt cover is the black plastic piece in the picture below on the right behind the upper radiator hose.
So what is the recommended mileage for changing the timing belt on a 4thG?
I too bought my rig used, and am pretty confident that it was never changed.
And as far as the sticker thing goes ... well, it's only as good as 1) a mech/tech that uses it; 2) how honest they are. :lol:
Has anyone just let it go and had the belt brake?? It would be intersting to know how many broken belts there actually have been because of mileage.
