It's kind of hot outside...
Hot outside
I don't think you can speed the fan up. It's probably running off of 12vdc from the battery. You would probably have to get a higher RPM rated fan. If it's not cold enough, you probably have to get the Freon Can recharged. I think they changed the coolant because of PCB legislation. So I don't know if they can recharge the original equipment or install a new system. On my 2005 SR5 4 runner, the fans blow out high enough and the A/C works fine. It's just in the winter with the heat on it doesn't blow out very strong when all front ports are open. Basically the outer ports at the ends of the dash-board are weaker than the main ports. Good luck getting it cold, it's all ready like hell outside.
After my black Limited has been baking all day, I get in, roll down the front windows and lift-gate glass. Drive out of the parking lot like that so the hot, stale air is moved out of the truck, close all the windows again and before I'm down the block the truck is at 78F degrees.
What temperature are you trying to get it down to? What color is your interior?
Okki
There is this tint called crystalline, it basically cuts out 80-90% of uv rays and it dramatically cuts heat coming through your windows. My tint shop had a demonstration in there lobby and I was amazed! They took the darkest tint possible (5% limo) and the lightest crystalline tint and put it on a slab of glass side by side they slid the glass in a wooden box that had a red heat bulb and you put your hand underneath each tint and I kid you not felt heat under 5% tint and having my hand under the crystalline tint felt cooler. Crystalline is a really thin layer of sheet stacked on top of dozen of other thin layers but it the same thickness as regular tint. This causes the uv rays that pass through the film to be defused x how many layers of film are in the tint. Look it up of course to it is expensive $500 all the way around and you can tint the windshield clear film and it would have the same effect that is $200 more, but shoot if your going to tint might as well use it this. The tint also gives you a better vision through the glass like those HD glass. Thought I should share this awesomeness.
BillM777
