I've got issue's
No idea what the two have to do with each other but I only notice the "thud" when the AC compressor is on. Maybe the GX's have auto climate control that can't be manipulated manually. I never use the "Auto" feature because it runs the compressor no matter what temp it is. Gas prices are too high for that nonsense.
Boston_Runner said:
Yes all GX have rear air suspensions. If you try to lower or raise the RAS, on some GX, the cluck problem becomes worst.
That is the EXACT same problem I have with my RAS!! Not only do I get the thunk when I stop the truck, but also when I raise & lower the RAS. I asked around here & the impression I got was pretty much "That's how it is...suck it up" (not in so many words ;): )
Hopefully Toyota takes a quick lesson from Lexus & gets the TSB out there. Is there anything we can do to possibly speed up the process? Should we report the issue to our dealerships? Should we bring the Lexus TSB to them & tell them we are having the exact same issues?
Personally, I'd wait a couple of months to see if the TSB really solves the problem. Lexus (which effectively IS Toyota) is quick to issue TSB's just to address complaints, but they don't always solve the problem. Cases in point are the 04 RX 330 dash rattles and the driver's window wind noise. TSB's were issued for both, but they didn't find the true cause for several more months and then the TSB's were re-issued.
Since some lube makes the clunk go away for a little while, I'd wait to see if the TSB solves the problem for longer than that. If the people on ClubLexus say it's solving the problem, then yes, I'd take the TSB to the Toyota dealer and get in line for the new parts.
I agree with that also, lexus already had a TSB out for this 2 years ago and it did not fix the problem. Wait a few months to see if this is indeed the solution before pissing off your local Toyota dealer. I will keep you guys updated if I hear anything. BTW the AC will make the cluck worst also because of the higher RPM.
I started this thread and I'll tell you , this thud thing is getting DAMN old and fast.....
I had my truck in for OLF maint. , but even after the grease job it still thunk's,almost seem's a little worse. I also find it embarassing when having people in the truck......come on Toyota get off your arse !!
rant over for now ..............
The only silver lining is that, apparently, this "clunk" does not harm the vehicle. From what i have been reading, this latest "clunk" fix on the GX is a success.
I know what you're saying - the thunk is getting old. Make sure they lubricate the slip joint via ZERK fitting. That always fixes it for me for a few weeks - then comes back.
You can minimize it by coming to a stop more slowly and releasing and re-applying the brake pedal once you hit 10mph. The will prevent the slip joint from binding up too much.
Hope Toyota releases a TSB for this soon...
