ive searched an searched so now i post
PhilthyToyotaSF
i recently purchased a 2001 t4r sr5 4x4 (after wrecking my 03).
when i purchased this 4runner i was told it was lifted 3". ive measured mine but yet to seen anything similar to measure and go off of. 265/75/16 Cooper Discovery. there arent any spacer shocks are stock toyota factory on the front and rear. possibly tacoma components maybe??
My question is whats stock ride height so i have something to go off of.
any info would help.
thanks phil
Stock is usually around 20" from middle of the wheel hub to the middle of the fender. Snap some pics of the shocks and coils in the front and back so we can try to determine the lift if you have one.
Measure the distance from the center of your hub to your fender. Stock (atleast for me) was around 19" front and 20" rear. I don't remember the actual stock numbers, mine had sagged a bit before I lifted it but it should give you an idea.
EDIT: [MENTION=53337]SCRunner12[/MENTION] you beat me to it haha. X2 on the pictures
from the looks of my stock rig. it looks lifted for sure. mines lifted now so i cant measure
i'll get some pics gota go pic up the kids and when i'm home i'll get them. thanks
i measured it was 23 3/4 frnt 23 something in the rear ill remeasure too
thanks for all you help its been a tough road finding anything out
Read BigFishAllDay's thread. I know he has a post showing the measurements fender to ground.
Just a thought .. Couldn't you go to the mall and park next to a stock 4Runner?
Post a side profile picture of your truck so we can see.
Lastly, use the link in my signature to do an advanced search (that actually works)...
Ok so took some measurements front 22 1/2 rear 23 from center hub to fender lip.
also here are pics if they help.
Driver front has some sort of spacer on the bottom perch, passenger front doesn't. I'd guess the springs are OME 882/883's. Rear coil has extra wraps at the top, which are probably OME 890's or something.
What's the part number on the rear tokico shocks? Could come up as the LC Tokico'd too, otherwise they're most likely overstretched stockers.
i'll look tomorrow when the sun is up. i tried but was at work and couldnt get dirty.
so the could be land cruiser stockers? and overstretched stock springs?
im tryin to find out so i can start my build.
thanks for the help
Not overstreched stock springs, I meant the shocks are either stock LC Tokicos, or they're overstretched stock 4Runner Tokico shocks. Rear coils are aftermarket I believe because none of the stock rear coils have the wraps close together at the top like the pic shows.
ok i got u loud n clear actually i went and looked i couldnt wait i want to see what it was and i found a thread you posted in i was still reading its this link. says........
TOYOTA
48531-60430
Z-C 1
TOKICO
JAPAN
THANKS SO MUCH FOR YOUR HELP!!!!!
so the front is posibally ome coils?
is this a "good" "OK" lift? can i get more with what i have by adding spacers?
http://www.toyota-4runner.org/3rd-g...nner-sr5-highlander-edition-4x4-build-11.html
Now that I think about it more, the front coils could also be Tundra TRD's..
they would have paint marks wouldn't they?
That thought crossed my mind right after I posted it, actually..
OP, do your front coils have any color markings on them?
TOYOTA
48531-60430
Z-C 1
TOKICO
JAPAN
That's the LC shock. Good budget shock for 3"+ lift. You could add spacers, but higher than 23" fender to hub will not play nice with your UCA's or CV's, so keep that in mind.
color like where ill go look im just chillin. tryin to figure this out.
struts are blue thats all i got. the right side has 351 PO73B on it the other has nothing
it looks like it also has the diff drop installed
