Over the weekend i installed the 167 hilux snorkel. There are a lot of photos people with cbi ditch brackets and the snorkel installed. I dont know how, but form my experience the snorkel hits the light brackets! There is no way it doesn't make contact for others. My only understanding is that when they rivet the window pillar, they push the snorkel, kinda like bending it a little. Also, it did not clear my antenna. It could be that my antenna mount is different from others. I did measure everything carefully, and i did it with the antenna installed. I have not used my radio antenna for years so its not a big deal. Ill just need to find a grommet to plug it.
There are few things that were little frustrating about the info on installing the hilux snorkel. There were no photos of how people laid their template on the fender to clear the ditch lights and antenna. There are multiple ways of laying the template and to your eye, it looking good. Comparing my holes to others, they seem dead on.
I feel like, i made the snorkel fit "to good" and thats why its having clearing issues.By issues i mean, the snorkel hitting the cbi brackets and not fully clearing the antenna. Otherwise it sits and fits flush! When i drilled my big hole. I put the snorkel in with the top black bracket attached. Then i made sure the snorkel was flush as possible, and that the bracket was flush to the window pillar and that there was no extra force needed to push on the top of the snorkel.
So these are my holes
From this view it looks like its blocking it, but its really not.
I dont know if this is mentioned in the hilux thread. But you need to remove the 2 bolts from inside the engine bay that hold the L plastic tube so you can twist it up and line it up with the snorkel one. Otherwise its impossible to attach the rubber hose because the difference in height is insane.
So what i did was. I cut the plastic intake tube that attaches to the L one that is coming from the engine bay into the fender. I made it few inches shorter from the 167 snorkel, and then cut down the rubber hose they supply and slid everything over. The gap between the 167 and the original tube is probably a inch. Which i highly down it will make the rubber hose collapse.
im pointing at those nuts that are welded. Thats the bolt that holds the elbow from engine bay. Takes those bolts out and you can spin it around.
So this is where i got really pissed because it kinda looks like dog shit. I heated the part that touches the cbi ditch brackets thinking i could push down on the hot plastic and reshape it. Well this is how it came out lol. But, it did give me little more clearance!!
The bracket is touching
This bracket... well NO WAY IN HELL AM I DRILLING INTO MY WINDOW PILLAR! I used 3m double sticky tape to attach this bracket to my window pillar. I dont care if it doesn't hold up. Replacing tape is safer, cheaper then new window pillar.
I used a bike tube to make rubber washers and some grease on the holes to prevent rust on the fender
So even with the snorkel touching. Which the issue is that it pushes your top part of the snorkel away from the window pillar which in theory makes it hard for you to attach to the window pillar. But i was about 1/8 inch shy from the window pillar with the black bracket attached to the snorkel.
I think it came out good though. There arent really any big gaps honestly.
