LC coil spring Color codes
lol I know right? Yeah, pretty sure that's what it is. What he said makes perfect sense.
All I can say is I've been running my LC shocks like so for almost 3 years and haven't run into any issues. But I suppose if you want to do it right, then bore it out. But I don't know of any member's running the LC shocks who have bored it out. I can't speak of what will happen in the future, but when I replace my shocks I'll take a look at the top mounting location and check it out.
I'm willing to bore it out, just want to know what these centering cups are, or if I can source them. I wish I could, I just can't afford any of SS' kits, even the rear only stuff. I'm building a craigslist/classifieds/junkyard lift here, but I still want to do it right.
you've seen this thread right? http://www.toyota-4runner.org/3rd-gen-t4rs/129104-attn-anyone-running-oem-black-tokico-80-series-lc-shocks-rear.html
These are what I was referring to in the other thread. You can buy it from the dealership, but they want an arm and a leg for it. These are the centering washers: (Permalink) http://www.toyota-4runner.org/3rd-gen-t4rs/129104-attn-anyone-running-oem-black-tokico-80-series-lc-shocks-rear.html#post1229570 BUT they don't fit on top of our top shock mounts without boring it out. BFAD ended up using 3rd gen centering washers.
That's excellent info. I'll add it to my thread as well. Dang, can't believe the OEM washers and centering cups are that much! That's like $68 in washers!! :wtf:
Rob is right there is no need to bore the hole out. I know that you can use a centering cup but all it does is wear the cup instead of the mount. I haven't used a centering cup in over 3 years and no issues what so ever. Go down to Ace and pick up some thicker washers and your good to go:cheers:
Well i just bought those shocks from toyota of dallas! It said there was a right and a left one so i bought those.
Thanks for the help.
Been doing tons of homework on LC coils and came across something (that may or may not already be known).
The parts for a 1992 FJ80 (in this case) are different for front springs depending on steel or alloy wheel. The alloy wheel is a 15x7 whereas the steel is 15x6. Looking at OEM tire sizes, the alloys are 31" whereas the steel is 28.878" in height.
With the different 7.5 and 8 wrap heights we see from the different color codes, I wonder if it's due to the OEM wheels that vehicle was equipped with? If so, would the taller springs be for the larger wheel/tire combos, in order to fit them? Then again I start thinking about it, and that would make the smaller wheel/tire model sit really low if they had SHORTER springs.
Thoughts?
Well my order just came in for the LC shocks and they didn't come with any washers. Ordered from toyota of dallas. What size washers should i get and could i just get them at any ace or dixieline/home depot?
Thoughts?
This is true. I havr all the specs on oem springs from TMP (toyota motor parts) ive posted it in this thread before IIRC
Looking for some quick advice regarding the lean I get with my LC coils.
I've got two of the same coils (double pink, light blue, white) and a 1" spacer on the driver side and I'm still getting some major lean. My current measurements are 24.75" on the driver with the 1" spacer and on the passenger I am 25.75." I have a full tank of gas which I'm sure is part of the reason but do you think it'd be worth swapping them over to see if they sit level?
I'm also running the stock panhard bar and currently my driver side coilover sits about .5" lower than the passenger.
Basically, do you think it's the stock panhard bar or the different age of the coils that's making the difference?
Panhard (trac bar) just centers your rear axle, it doesn't affect ride height.
ok,
Duhockey- 19.5" Purple Green White 8 wrap- driverside
19' Double Purple light blue White 7.5 wrap- pass side
both off 93 LC fj80
FoneRunner- 19" Double Purple Light blue white 7.5 wrap - driverside
18 7/8 orange orange white 7.75 wrap - pass side
no vehicle specified
Rusm- 19.5" double Purple Green White 8 wrap -
19" Doupble Purple Light blue White 7.75 wrap
99Yota4- 21" Blue Pink White 9.25 wrap
21" Greg orange White 9.25 wrap
of a 91 LC (fj80 or fjz80?? )
GonzT4r- 21" Blue Pink White 9.25 wrap
91 LC (fj80 or fzj80 not specified)
Elton H - 19.25 Double Purple Dark Blue White 8wrap
SteezeMcqueen- 19.5" double Purple Green White 8 wrap - drivers side
I know this thread is old but, if fits perfect for my research needs along with answering many of my ?'s. I purchased a set of LC front springs, I do a study before I do any purchasing. But now I'm 2nd guessing myself and not sure if I messed up. I purchased what I believed to be a matching set off of (1994 Toyota FJ80 Land Cruiser Front springs. For a rear 99 limited lift. Color codes are as follows,
(PP + D\BL + W) & (PP + L\BL + W) I thought they were a matching set right & left. With that said, I now I realize one is 8-wrap and the other is 7.5 wrap.
Going by the color codes, along with just standing them up side by side, and putting the tape to them I got 19.25 on dark blue &, 19", or just hair under 19" on light blue I did not lay straight edge on top so just eyed the tape anyway, there is a slight difference about .25". Which is right on, with this post.
My question is. are this matching set is either left or right supposed to be .25" offset for some reason weight is everyone one side then the other. Or did I buy a mismatched set and have to fab something up?
Should I have purchased
All the Double purple light blues set you have listed here have a Drive side with green on the 2nd dot, not the dark-blue 2nd dot?
you will be fine with what you got. put the 8 wrap on the drivers side (gas tank and driver) and it will sit fine. I have 8 and 7.5 wraps and love them.
I just got my Sanoran Steel 1.2 Rear only lift last week. Both of my coils are color coded:
Double Purple / Grey / White.
Both are the same part number: 48131-6A570.
Hope I don't lean. LOL.
Can anyone point me in the right direction as to which springs these are? They don't appear to fit the color key legend that is passed around here. Local shop sold them to me and said to try them, currently waiting for my 5100s to arrive.
Mine are posted below and have heights of 20.5" and 20.75"". They both appear to count around 8.75 wraps but the colours don't seem to correspond. Can anyone share any insight? My colours seem to be Orange Grey White and Orange Orange White. Assuming it is orange since red isn't on the key.
img_0056-jpg.1340291
Can anyone tell me about these I was told that they where 2inches and that they are extra heavy duty and they are for a toyota prado
did you get them installed? Do you have lean?
I had them installed about a year before swapping them out for ARB OME 861's. Mine did not lean. I suspect that the year 4runner might have played some part in what color code LC coils gets when they order from SS. Their SS 1.2 rear lift is broken down by year pairings. 1996-2000 is one package, and 2001-2002 is another. I know a few others had to use trim spacers to level things out. I was lucky and did not have to do that. If I would have stayed with 265/75/16's, I would have not changed a thing. Probably would have been easier too.. lol.
I'll add my 8 wrap colors. I bought them from the classifieds here for $60 shipped so I dont know what year LC they came from.
Purple-Purple/Blue/White
Purple/Green/White
So you dont have to search the thread for the color code info... I posted the quote from Ih8mud
"yep the color code is the definitive ID
Here is a list of color codes from the front springs I went though today
Height/color code/wraps
21" Blue Pink White 9.25 wraps
21" Grey Orange White 9.25 wraps
20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
19" Double Purple Light Blue White 7.5 wraps
18.5" Double Purple Grey White 7.5 wraps
18 7/8" Orange Orange White 7.75 wraps
From what we could tell all of the springs use about the same gauge wire. only 2 of these were from an LX450 so the LC and LX have springs in common at some point year like CDan has been saying all along, unfortunately I do not know what year belongs to what color code."
do you know where we could buy these new? preferably these?
chasebradshaw
