LED Headlight Bulbs - Check em out!
9005 9145 H10 HB3 5K MT-G2 3000LM LED HEADLIGHT FOG LIGHT DRL HIGH BEAM | 1 PAIR - 9005 9145 H10 HB3 - LED - Headlights
it looks like they have a 3000 lumen version for the 9005 application (high beams). Are folks still super happy with their V-LEDs or have people been wavering?
I'm thinking VLEDs for the high beams...
H11 MORIMOTO ELITE HID SYSTEM for the low beam and
Morimoto XB LED Fog lights
this is for a 2014 Limited.
I just got a 2014 and will be waiting for your install and impressions. Your thoughts have been mine too.
whats goin on, kinda new here, recently put in sylvannia hi and low beams H11 and 9005, thought they would be a bit brighter but im looking for something really bright for my low beam replacement. im not looking to add an led bar or pods. if anyone can recommend a slight blue tint or super white low replacement bulb much would be appreciated. also how do i turn on my fog lights they are never on when i turn the headlights on.
any reviews on the LED head lights.....
VLEDs
3000LM total output (per bulb) on the LED style (30 watt power draw)
VS a
xenondepot
3000LM ( assuming per bulb) on an 5000K HID 35 watt power draw.
what is the real advantage one vs the other
VLEDs
VS a
xenondepot
I wouldn't run either one. Do a real retrofit and run OEM D2S bulbs
and another question anyone actually put them in the 2014 lowbeam slot to see how they work with the projector....
ya ya I know that they say not for projector ideally.... but was wondering....
Ya ya ya, it has been done and the verdict is it's not ideal.
Sounds like you are a H9 bulb candidate. It is a super easy conversion and it made the lights so much better. Order bulbs from headlightbulbs.com to see the different tints. I think super white has some blue in it.
If it's been done, do you happen to have a link where there might be photos? I don't see why it would be less than ideal in the 2014 projector headlights. Or do you have pictures? I haven't seen any thread where someone has put LEDs into these housings.
I have two DDM HID Kits coming that I will install and post about. i have these in multiple vehicles of mine that contain projector style housings and work like a charm. Lifetime ballasts. Ordered both a 55w 5k kit and a 55w 6k just in case 6k is too much blue
+1
this is exactly the set up I've come up with for my TRDP after looking at all the retrofit posts.
except I'm going with xenon depot h11 4300 phillips hid bulb...closets to what manufacturers put as OEM on cars now days from I've gathered so far. i don't like the blue look of the 6000+ bulbs
however, looking at the Vleds site, they do make note that their h11 Leds are good for projectors
http://www.vleds.com/headlights/lmz-ho-17.html
this are 3000lm bulbs and they also have 4500lm bulbs! ouchy
anyone tried these?
I don't see why the verdict would be less than ideal. I have not seen any post by anyone that has installed LEDs into the 2014 projector housings. Do you have a link with photos?
Someone was asking about LED or HID in the projectors. Then a comment was made about not doing either. I was referring to the HID install.
Edit: Not that I think the LED would be any better.
I don't know....maybe because the projector was not designed for that bulb.
From my research and talking with TRS and VLEDs people, it seems that LED bulbs don't work well with projector lens because of the way the lens collects the light.
With an incandescent bulb, the light is thrown in all directions, 360 degrees.
With an LED, the light is thrown only in the direction that the LED is pointing. This makes for weak spots or shadows in the light coming out of the projector.
I am still thinking about getting a pair of LEDs and trying it, but the only thing is that if the result is crappy, I have a swallow a bunch of money. I can't find a place that does free returns.
Get a pair, if it works, it works..... if not, throw them in your fog..... and apply yellow film...
MaximussK
