LED headlight question
i used a spade drill bit for the dust cap. If you leave the dust cap off, you'll run into problems with moisture and dirt getting inside of your housing.
Did you apply some silicon or anything around the cable to keep it sealed?
no, if you're replacing with an aftermarket bulb; it should have a rubber grommet that fits and seals the hole after you have drilled the dust cap. If the hole that's drilled into the dust cap is slightly bigger than the rubber grommet than yes i would place tape around it to prevent moisture from getting inside.
https://www.youtube.com/watch?v=Pf9_c7QTCEU&t=379s (you'll see what im talking about starting around the 2:30 mark)
The katanas fit inside the dust cap. I didn’t modify or cut anything for them to fit and have zero issues.
As for adjusting, do it while it’s darker out and aim it against a garage door or something so you can watch the beam pattern.
The HID kits you’ll need to modify the dust cover. These you don’t
Thanks. Of course I figured that out after drilling a 1/2" hole in each cover.
I'll find a 1/2" rubber plug at the hardware store.
I tried a few LED kits but each would have dark spots or a broken beam pattern. I found the Katana works extremely well in my three 4Runner's. I get a really nice beam pattern, a good match to my OEM pattern with a much higher brightness and no dark spots. I agree with some other forum members - this bulb seem to match the Supernova V4's at a third of the price.
Installation in my 4Runner's was a bit tight, the cable and LED driver are a little larger than some other bulbs. I just took some time to try a few different ways of mounting and installing the LED driver behind the headlight housings dust cover. I found the best way to get everything to fit, was to connect the factory wiring to the LED driver and get it installed with the drivers base flat against the bulbs solid aluminum mounting block, then install the bulb and connect it to the driver.
I also decided to keep halogen's in the high beams because of the DRL flickering issue, I did replace the stock 9005's with 100W temperature matched bulbs that are super white and come close to the LED's.
Upgraded the fog lights with a inexpensive Alla Lighting 2800lm LED Fog Lights Bulbs set that seems to work well. I choose these because of the internal driver - time will tell if they hold up.
All in I am very happy with the results - far improvement over stock.
I just ordered katana. For the fogs, are these the ones ?
Thx,
Alla Lighting 2800lm H8 H11 LED Fog Lights Bulbs Xtreme Super Bright High Power COB-72 Cars Trucks H16 H11 LED Foglights DRL Replacement, 6500K Cool Xenon White https://www.amazon.com/dp/B07G5WJ4ZK/ref=cm_sw_r_cp_api_i_txb5DbMP9BWJD
Yes, those are the LED fog light bulbs that I am running. Seem to be a nice match to the Katana low beams. Let me know how you like them after you get the installed.
Fogs arrived today. They are nice and bright. Thanks for the recommendation. The low beams I have now are Fahren, also from amazon. I plan to swap them out with the Katana as these have some defect on the cutoffs.
I tried the Fahren bulbs also, I found the same as you not a great cut-off and a few dark spots, switching to the Katana bulbs was a very noticeable and positive change. Using the Alla fog bulbs with the Katana low beams, to me, provides a great coverage pattern, I think they work very well together.
These led h11 are okay, but they are not as bright as Oem led like Bmw and Lexus. But they will do until I get something like morimoto xb. I just want to see them in person before I buy them.
Are these the katanas on amazon?
KATANA H11 LED Headlight Bulbs w/Mini Design,10000LM 6500K Cool White CREE Chips H8 H9 All-in-One Conversion Kit
$35.99 a pair
$35.99 a pair
Here are the katana h11 I got. They are awesome. Very bright as drl and nice high beams. There’s some flicker as drl but barely noticeable.
The ones I got are $48.99.
KATANA H11 H8 H9 LED Headlight... https://www.amazon.com/dp/B078W5WJZ2?ref=ppx_pop_mob_ap_share
Glad I found this post! Previous owner installed Auxbeam LED's and the passenger side low-beam output was essentially non-existent because of how the LED was sitting in the projector.
Ordered some Nineo's off Amazon, delivered in a day and they are night and day better than the Auxbeams. Took me about 30 minutes to get the adjustable mounting right but once I got them in place they are solid! Perfect fit, no issues whatsoever. Adjusted the aim on the headlights themselves and am thoroughly impressed. The fan on the Nineos are about 20X quieter than the Auxbeams, you can barely hear them with the engine off. The Auxbeam fans you could audibly hear with the engine running.
FWIW, my high-beams are also Auxbeam and they work great, extremely bright. If/when the Auxbeam high-beams go out, will be ordering Nineo's as replacements.
KATANA H11 H8 H9 LED Headlight... Amazon.com: KATANA H11 H8 H9 LED Headlight Bulbs,CREE Chips 12000Lm 6500K Extremely Bright Conversion Kit,360 Degree Adjustable Beam Angle: Automotive
Sorry to resurrect, I just got these in for my wife’s sr5. What did you do for the ballast? Drill through the dust cap?
Guys, I just got my 2020 TRD. Does the low beams and high beams use the same style bulb? H11?? So many different types, kind of lost here.
Thundro
