LED LIGHT BAR INSTALL on a 2014 T4R
Great thread...is there an ideal spot to locate the 3a inline fuse on the headlight trigger wire? Near the headlight or near the switch?
[MENTION=90192]2chains[/MENTION]......thx!
IMO it would be easier to install at/near the headlight as that is where your other fuse will be located for 12V power to light system.
thanks, how's your light bar holding up? Are you finding it remaining stable in that mounting spot?
Doing fine. It's as stable and secure as the day it was installed!
Mounting point is directly into the bumper, drilled and tapped.
Use quality hardware and it will be fine!
[MENTION=103267]Saker[/MENTION] should have put in a patent on this. Saw whilst trolling through Instagram .
I really don't understand why I cant find a bezel/trim kit/flush mount 20-30" LED bar. Does no one make one?! This is kinda mind blowing to me...
Look thru my thread for some info on how mine is made and photos on how it is fastened. You will see in the photo that the grill is sandwiched between the bezel and a flat piece behind the grill.
You could get the dimensions needed to have your own bezel/trim made locally if you have a water jet company or a sheet metal company close by.
It's not hard to do.
I think if you have your own made, it will be more satisfying and you can play with the design on paper or with a piece of cardboard first to tweak it!
I think the reason no-one makes them is because there are so many variations on bar sizes and configurations.
Thank you Saker for the thorough and quick response.
We are going to use your solution to frame my light bar to give it a perfect fit and finish. I sure hope it turns out as good as yours did. Mine is a little wider so we'll see how it works out with the curve of the grill. My light bar is straight, not curved. Had we realized the grill had a curve to it first, we would of purchased curved bar! We got a great deal on it, so we'll make it work.
I will make sure and add my install to your very informative thread. It may take some time, but it'll get done. Between work, kids, life and the fact that it is horribly humid and hot here right now.....it will take time.
I'm curious how the curvature of a larger bar (20"-30") would match up with the curvature of the grill. Any thoughts?
I don't have a clue.
I guess you will have to do a fit test and determine if it will work for you....
Wish we had some data to help guide us to what will work behind these 14 + grills. I guess only time and each of us posting will be our only guide!
When you get it figured out, please post your results so it will help others wanting to accomplish the same and when the project is complete, post some photos please!!!
Great write up Saker! I have had this thread bookmarked since before I bought my T4R, I knew it was something I wanted to do.
I do have one question...how/where did you run the wires through the firewall into the cabin?
I have a 32in LED bar, harness and switch waiting for me at home, I can't wait to get off work and install this!
Thanks [MENTION=126399]br14n[/MENTION]!
"through an existing rubber grommet on the firewall near the master cylinder"
Be careful when you use an awl or pointed punch to make a hole in that existing grommet so not to nick any other wires. Don't oversize the hole either so it will remain watertight.
Hope this helps.
Thanks for the mention Antman! :)
AOB has been having a few issues with their supplier, so the website has been up and down.
I suggest going to their "contact us" section and sending them a note telling them you are interested in one/some switches.
Best I can do.
I am almost done installing but I don't know which wire to connect to the blue/wire signal wire from the light bar switch? I want to connect it to the exact same button OP has it connected to- but theres like 6 wires going to that button?!
Can anyone help me out as to which wire to connect to? Theres blue, pink, white, red
I'd appreciate any help!!
Hey [MENTION=131305]Joes14T4R[/MENTION],
This is what I used for illumination to the swtich.
Here is the post: http://www.toyota-4runner.org/1752196-post67.html
You guys spaced/drilled the bumper beam for this; are you able to fish a bolt up through the bottom of the bumper and then put the nut on from the top?
I just put in 20" bar on my '14, by running two 4" stainless bolts down from the top, and "hanging" my bar upside down. No cutting/drilling, and works fine on the road. But off-road it vibrates more than I would like.
image_zps069f80bd.jpg~original
Do you have any pictures of the install? Where did you run the bolts?
If you read thru the thread, it's post # 67!
:shocked:
Sorry if i missed where it is but did you provide a link to the switch you used? The push switch that says LED Bar where did you buy it? The air on board site i guess doesnt have that same switch anymore they seem to have more fancy ones now =p but also EXPENSIVE when you have as many LED Bars as us and need switch for air compressors and lockers etc it adds up lol =/ how much did you pay?
I did provide the link to the switch, from AirOnBoard USA
TOYOTA 4RUNNER Replacement Switches -Air On Board.
Seems they don't have any Blue On/Off in stock, at all. Lots of times it is just the time of year. Oh, I paid $27.00ea.
You could try this:Toyota OEM Switch | eBay
or
Slee has some, but not the LED bar illustration.
Aftermarket Toyota Light Switch
Part: STF1056 - $27.50
Switch Face Dimensions; 23mm x 33mm
Aftermarket Style Toyota OE Switch which is compatible with all the newer style dash knock-outs. Supplied with the plug and wiring pigtail. Only available with green illumination.
2001ATL
