Whitebeauty
Good work man...you definetly like your lights huh... They look good man...:nicethread:
Hi riceandpho, where is the interior fuse box? Is it in the driver left footwell under the dash?Flasher relay is located on the back of the interior fuse box
No I don't recall if there was another plug next to it. I remember that there is a plug going into the 12 pin, but not anything else near it.did you see any additional wire harness after that drl flasher box you took out, i think there is a plug right next to it and its 8 pin.
Yes, I removed all 4 bolts including the bracket mounted to the wall. The OEM flasher relay is installed on the back of the fuse box as you'd mentioned before, so there is no way to get to it without removing the fuse box itself.riceandpho said:u did make sure to unblot the inside fuse box to get there right, .
Not sure what you mean by this. Please explain a bit more. Thanks for your help!riceandpho said:i was able to reach and leave it there
I'll attempt to do this when it gets warmer. Hopefully next weekend. Thanks for your help.The led flasher relay replaces the factory relay, take a pic of the back of the fuse box , see where the 12 pin plug go to, it should go to a 8 pin plug, i do recall seeing it in a service manual. I think u might lose the day time running lights.
I finally got around to checking this and there is no other relay further back.The led flasher relay replaces the factory relay, take a pic of the back of the fuse box , see where the 12 pin plug go to, it should go to a 8 pin plug, i do recall seeing it in a service manual. I think u might lose the day time running lights.
i dont have drl in my truck, the next thing u can do is use 2 resistor, one on the left and one on the right.
bumping this thread since it was 7 years ago where everyone was doing this, some really over did it. i wonder if i should bring this back.
How are the LED strips holding up after all these years? Do you have a link to them?
Lol they definitely became a standard across most vehicles it seems now. Been thinking about doing this with the full outer edge wrapped, using diffused LED tubes. That will come with a full retrofit though
might be a little tight on the space if you try to fit that in the gap of the trim piece and headlight lens. but inside of the headlight might look weird.
I've been contemplating doing this and what would look the best. I was originally thinking of doing a "C" with the outside open. But wondering if that would be too much. I do like the simplicity of just the bottom.
