bpwwer
Next stop is read up on the 2014-2015, then try to contact the seller and figure out about
- getting wedges
- how to get a 5630 festoon that fits better.
and I think other forum members have already done so.
I've tried a couple of different bulbs. I have a 28mm 5050 festoon bulb in my dome light now. It matches color wise with the other bulbs but is noticeably not as bright. The 28mm is actually a little shorter than the original bulb. All of the 5630 bulbs I found were 31mm which seems to be slightly too large. I think 29 or 30mm would fit perfect.
I also have a panel that comes with a festoon adapter. The adapter is spring loaded so it should fit easy. The panel uses 12 5630 SMD's so I suspect it will be really bright, but I haven't tried this yet.
The 31mm bulbs will fit pretty good if you bend the spring tab so it's almost flat. I know, this is almost useless without pictures. I'll try to get some tonight.
