LED Turn signal bulbs
Well for shitts and giggles. I changed back my front blinker bulbs to incandescent. I have blinkers again, but with a bit of hyper flash. But I can love with that. Look how much brighter the right one is. That is the old bulb. I got what I paid for from amazon. AWE :censored: !!!
Which one is the LED, the passenger side blinker or the driver side blinker?
Well unfortunately they did not carry what I needed. But I did get confirmation that I had the correct part. I will order one online i guess. I also located the flasher relay its in the Driver side kick panel just FYI
Hey gigerunner, when you install new electronic flasher, might you post a photo of the original flasher in its location. Thanks, I don't want to pull(rip) out wrong component.
i did an led swap all around on the outside of my 92. i had to install load resistors for the turn signals fornt and back, but total cost was less than 25$ off amazon. 4 load resistors were 5$ and each led was less than 4$, plus s&h and tax. but when i installed the led brake lights i came into a small issues. if all my lights are off and i press my brake pedal, my parking lights come on, including dash lights. its kind of annoying and a little embarrasing. so i usually just turn on my parking lights when i begin driving (those are led too) any ideas on why my circuits are mixing up?
I got a pair of shitty brake LED's that somehow turned off the running lights when brakes applied. I put the incandescent back in. I am ordering a more expensive pair now.
I only skimmed the post. But I did a total LED light replacement on my 85 86 87 88 pisa runner and I just opend the blinker relay and cut out the little resistor out that is for low voltage warning (ie blown bulb ) and it worked perfect. There is a wright up on it in Toyota 4wd owner mag.
