lets see them CB Antenna Mounts
I've been a ham for a few years now and running CB's even longer. I went with permanent mounts on my Jeep Rubicon (back in 2004). But every other vehicle I've owned I used strictly magnetic mounts.
My transmission and reception are always very good in the groups I run with. I frequently find I'm able to get out (transmit and be received) from locations no one else is able to. When I'm running both CB and short wave I will generally sacrifice CB location on my roof top and give priority to locating the short wave antenna on the roof for best performance. Then I move the CB as far away as possible (e.g. the other corner) in order to get best performance in best radio but at the same time minimizing any possible interference between the two.
I've always bought high quality antennas with the rule of thumb being put your money in the best antenna and the radio will generally take care of itself. I am not suggesting going cheap on your radio equipment but if you're on a limited budget don't scrimp on the quality of your antenna.
I recognize that many of you are probably thinking you don't want the aggravation of dragging an antenna out everytime you are going somewhere. The convenience of just folding up or down is definitely appealing. But two thoughts for you.
1) You can go with a quality mag mount base with a threaded connection on top. Then you buy a CB or short wave only antenna with a matching mount for screwing in. You can permanently route the wiring and leave the magnet in place full time. When you want to install the antenna it is a fairly convenient screw in. And the antenna can easily be stored on board somewhere.
2) Even with a folding mount you still have to get out and put it down for entering the garage or pulling it up when needing to use it.
Just an alternative that I've had success using (but also with acknowledged limitations).
+1 on the magnet mount. :thumb3: Ran that magna-mount set up looooong time ago with K-40 antenna, and woked like a champ, even for DX contacts
Anybody care to talk about HF Antennas for a second?
I've got a CR8900 on the back hatch using a K400 mount I think. Performance has been fine...no issues but I think I want to lower my profile and go back to a qtr length antenna.
I don't think I'll change mounting location - all I think I want to do is change out the antenna itself.
I'm thinking of a Comet B-10 I think.
Thoughts?
I did Google but couldn't find a source that I'm used to dealing with. I apologize for posting.
No need for an apology or to stop posting. I simply answered what you asked, then you changed the qualifiers. I tried Amazon and got several hits.
http://www.amazon.com/s/ref=nb_sb_n...mond+k400+mount&rh=i:aps,k:diamond+k400+mount
If not Amazon how about Ebay? Yup, several hits again. I can't know who you deal with without you saying so...... :wink2:
diamond k400 mount | eBay
Where did everyone get their Diamond k400? Any links to website?
Since you don't seem to be having much luck getting this answered (don't buy on Amazon, those prices on the K400 mount are rediculous) try hamradiooutlet or gigaparts.com. Not sure which mount you need so I didn't link you directly- the K400 comes with and without the stud/coax/etc depending on what you actually need. Without the mount, average I've seen is around $40.
Hope that helped!
Hope that helped!
Much appreciated. Thank you.
I did the same thing as [MENTION=90395]Sundog7121[/MENTION]
Don't. Rust issues galore.
I just looked at my K400 mount after having it installed for a couple of years now... and there's not only rust on the hatch from the mount, but rust on the opposing side due to the set screws digging into the opposite side.
Sigh... after I get rid of the rust and move the mount lower, I'll try to protect the bare metal with some sort of sealant.
I went back to look into moving the mount lower and using a 2' Firestik so that the antenna is flush with the top of my car. I never end up using the CB because I keep having to take the antenna off before going into a garage and it just ends up staying off. Reception might suck after the move, but at least it's better than nothing.
Hahahah. I knew you would throw some shit talk up in here.
Gotta get it in where I can....ayoooo!! In all honesty, I wish my truck didn't cost me what it did because a solid mount solution like that is what I'd love to do, but I just could never bring myself to cut into the body of my $40k SUV haha. Diamond K400 mount it is!
MaximussK
