lets see your interior mods
Where'd you get those light switches?!
CH4x4. You can use pre-designed ones like I did, or custom design your own for a few dollars more.
https://www.ch4x4.com/product-category/push-series/toyota-small-push-switches/
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=toyota+push+button+small
Also another place to look is
https://www.aironboard.com/online/products/switches/toyota-push-switches.html
***Caution*** you have to order the "small" push button, and may have to shave a little of the side key. ***
That’s very clean , what was your mounting solution?
Already being mauled by a bear??? Can’t get to drivers seat/under attack.
Right... which is what I was getting at. If you cannot get to your drivers seat, or are being mauled/attacked, why are you going to be able to open your trunk and unhinge your shotgun?
I think it's kinda tacticool, but definitely not for me. And, I say that as a CCW/hunter/gun owner.
Thermoplastic, heated and bent into clam shape around the bar there. The other side to which tools attached flat and secured with 2 small bolts and nuts. No drilling. All completely reversible.
Alpine Halo9
I thought some might want to see the 9 inch Alpine floating unit. I had trouble finding more than one or two pics before I purchased. It doesn’t really cover the vents as much as it looks in the picture. I’ve had a few people ask me if it just came standard with the car since it doesn’t look “after-market”
That looks awesome! I wish that was around when I swapped my head unit for a pioneer. I would have gone this direction instead.
Congrats!
Could you post some pics of that from the side, basically from the worst angles, so we can see what's going on there exactly? Looks really cool!
It's a place to carry/ store it.
By your logic the flashlight or fire extinguishers mounted in the back also serve no purpose then, because what if it gets dark or a fire erupts and you are away from the hatch and can't access those implements?
It also is a kickass clothing rack!
And, when camping in the back, as previously mentioned, it IS easily and rapidly accessible, way more so than crawling over the front seats and trying to drive away:
I don't disagree about the location when camping in the back. In fact I think that's an absolutely great use case for the mount and location.
Continuing with my logic: flashlights mounted in the back... Don't really think that's a huge ordeal. Car has interior lights. And if for some reason they are all totally dead, it's probably not a life or death situation when you have fumble around to find it. The extinguisher on the other hand...while absolutely better than nothing, I do think the way Lawndart and other have theirs mounted under the front seats is worlds better than being in the trunk. And, if I were to mount one, that's how I would do so.
Hacked the front and rear cubby holes to be a wee bit more functional.
Did you mount the compressor in the rear or just run airline back there? If the compressor is there, what size wire runs back from the battery?
Compressor is mounted in the rear. I have some electrical back there and used 0 awg cable to power it all.
Wireless Apple CarPlay system along with a bunch of other audio/supporting upgrades: Focal speakers/tweeters, Alpine amps, Rockford Fosgate sub in custom enclosure, Maestro factory steering control/backup camera/USB port integration and onscreen OBDII data, custom paint matched dash trim.
Ham radio in the center console.
Tuffskinz inserts
LED interior with ARC Light rear hatch LED panels
Canvasback liners, Husky Floor Liners, Rago MSP's, Sub woofer in rear pocket location
What tough skinz did you order. Looks like the same set up as mine but their website pictures don’t show the 2 compartments under the heater controls don’t wanna order the wrong ones.
I got the 4WD set, they accidentally sent me the 2WD set first and I had to exchange, but the 4WD has the pieces under the heating controls
That looks amazing!
Random question. Does your headunit have a setting to automatically turn off the screen after 15-30 seconds of inactivity? My old alpine unit in a previous 4Runner had this feature, which was really convenient for driving at night. The glare from my screen is almost blinding at night (I know you can turn it off manually, but not very user friendly).
