Pastanoose
Looking for input and advice on lifting 2010 Trail
Hello, about to lift my TE. Going with bilstein 5100's front and rear, that's the easy part. Deciding the combo of coils/spacers and what not is the challenging part.
This is my daily driver, I drive 95% on road. I do long road trips and lots of camping with kids and a loaded truck. I do moderate offroading.
Cheapest is obviously:
Set Bili to 2.5" front and put a daystar 1.5" spacer rear.
Front thoughts: Set bili to 2.5". It seems like toytec has both a 1.6" and 2.5" superflex spring for the front. I could go with the 1.6" and set bili to .85"
Rear: Daystar spacer 1.5". Toytec spacer. Toytec superflex spring 2". Sway-a-way 1.5"
I looked at the OME springs but I don't want 3" as that pushes the limits of needing UCA's. so most likely going with either just 1.5" up front to level or 2.5" and 1.5"
What is your setup? What are your thoughts and recommendations on this? Anything you would do different? Also I will most likely have it installed at 4Wheelparts.
Thanks!!!!!!!!!
Thanks!!!!!!!!!
