Not me, I'm in Farragut and work in Roane co so I'm always out west. I'll keep an eye out for ya when I'm around town.
Looks good! Which brand spacer did you go with?
315.70.17 Duratracs![]()
Sent from my SM-G930P using Tapatalk
Briefly looked through your build thread, it looks sick!
If you don't mid me asking, what offset and back spacing do you have on your wheels and do you think your 315s would rub more if you had a stock front bumper?
I have stock wheels with a 1.25" spydertrax spacer. Im rubbing on the swaybar currently on full lock. Im sure A LOT must be done to clear the stock bumper, I do feel the shrockworks does aid in fitting these beasts!
Replaced all the suspension with OEM then put the DS 2.5/1.5 spacer kit in. Wheels are the OEM 5th Gen 17s wrapped with Hankook Dynapro AT 265/70s. Currently running Spidertrax but might swap to wheels with different BS to avoid using them.
Just got my wilco solo installed.
Is that the standard Solo or the high clearance version? Looks good!
Sent from my SM-G950U using Tapatalk
Well, I've finally got a little lift and a decent set of tires, so here it is:
2005 V8 4WD SR5 w/Third Row
Daystar 2.5/1.5
BFG AT KO 265/70/17 (by the way - the spare fits just fine)
FJ Cruiser Wheels (bought the set of 5 used from a great guy on the FJ forums---now I gotta try to unload the stock wheels and tires)
I've also got the Scion/Pioneer head unit installed
Next up is installing the FJ Cruiser Trail Team suspension I have in my garage, or any other suggestions......
By the way, gas mileage sucks.
I've been scrolling through this thread all day, so I want to ask...
I have the xreas suspension, which I'd like to keep until it goes out, but in the mean time I want a little more ground clearance. I'm currently running 265/65/17 BFG A/T KOs. I'm wondering what spacers I'd need to fit the 265/70/17 KOs without rubbing or trimming. 1/0, 2/1, 2.5/1.5?
Any help is much appreciated.
Do you have spacers on? It looks a bit wider than I would think those wheels would make it.
