Lift and Tire Central (pics)... Post 'em Up!
2003, Old Man Emu (springs: 885 medium load front/90000, 895 medium load rear/60000), Spidertrax 1.25 inch wheel spacer front only, JBA UCA, 285/75R17 Maxxis Buckshot 2 on stock wheels
Been meaning to make a build thread on here but haven't quite got around to it yet and don't think I've posted any pics of my rig as of late so here it is with the big boy tires! 285/75r17 KO2's on FN Konig Countersteers, wanted to keep things as light as possible at each corner and I'm glad I did, barely notice the increased stress.
Sent from my Pixel 5 using Tapatalk
That looks great! More pics required. What lift are you running?
Sent from my KB2007 using Tapatalk
Ocotillo / Fish Creek Trip 10/9
Here are some photos of my overnight camping trip in Fish Creek. Funny how the sand makes my bumper paint looks cracked after the ride. It was a fun ride to the Pumpkin Patch and my 6112s worked flawlessly. We were able to hike Slot Canyon as well.
Mike
I'm running a 1in bodylift, Dobinsons IMS lift with medium weight springs at each corner and the extended travel rear, SPC UCA's, no front sway bar, superpro extended rear sway bar end links, and 2in bumpstop drops. I believe that's everything. I'll start a build thread at some point soon and get more pics up here
Mike
Like the black rims with the silver. I just got a silver '04 and making me think about switching out the stock rims for some black ones.
Thanks APV! Actually they are a dark bronze from Fuel Wheels. I didn't like the light bronze from Method or other vendors on Silver so I chose Fuel.
Mike
07 Sport V6
Toytec Aluma Series Coilovers
Toytec Rear Superflex Coils
SPC UCA's
285/70/17 Nitto Ridge Grappler's
Method 703 in Titanium
Had to move the liner forward a few inches and minor cuts to the bumper, otherwise no rubbing.
07 Sport V6
SPC UCA's
Nice build!:rockon:
My 2005 SR5 4wd is coming up on 200k and starting to show its age with a little wobble at 60 MPH. I know I need to replace the hubs/wheel bearings and figured I'd do a refresh on the front end. I just moved to Denver so picked up a couple of CVJ Reman front axles and also ordered JBA UCAs.
Right now I'm riding on Bilstein 5100s (fronts at .85) and FJ Trail Teams springs all around. I have about 50k on a set of 255/75/17 Cooper AT3 4S (32.2") on 5th Gen TRD OR wheels and they've served me well but I'm looking to move up to some 33" Falkens so I may try to lift it another inch or so. I've considered adjusting the Bilsteins up a notch or two but I think I'd rather not compress the springs that much. Can anyone recommend a set of springs that pair well with 5100s (and can fit a 33" tire without setting the Bilsteins above the first notch or two)?
Also - are there any other items I should look at or replace while I have everything apart? I think it would made sense to do the lower control arms as well - is the consensus still that Toyota OEM is the right move there?
Have any additional pictures of the 255/75/17 for the Coopers? Love them on our Yukon and thinking of doing the same on the 4Runner
Runadun1220's 4th gen
-2004
-3 inch suspension lift
-285/70/17's Arturo trail blades
Biggest size tire with stock suspension
What is the biggest size of mags (i really like the ray10 of SCS 17/8.5 -10 offset) and tires can i put with a stock suspension without rubbing.
Im sorry to ask here but i didnt found another way.
Really hope you can understand my question, english is not my first language :D
Just got new shoes: FALKEN WILPEAK 265/70/17.
Pair with moog FJ springs and 5100's all around. Front 5100 are one setting higher to lever the front20211106_104059.jpg20211106_104115.jpg20211106_111026.jpg
Sent from my SM-G986U using Tapatalk
Will take better pictures soon but too excited to not share now
Bilstein 6112 with 650lb coil
Total Chaos UCAs
Bilstein 5160 with Icon 2” coil
SCS GEN 5 | 17x8.5 -10 offset
Falken Wildpeak AT3W 285/70/17
Car looks great! Do you happen to have pictures of the shock body of the 6112 upfront to show which perch level you are on? I believe mine are setup for 5/3 to compensate for lean but it does not look nearly as high as some of the others on here. Maybe I will need to upgrade to the 650 springs as well for the additional weight of my RTT.
