That thing looks great! What grill is that? I tried sending you a direct message but the new forum layout is acting weird on my phone
Its from srqfabrications.com
2003 Limited 4WD
Bilstein 5100 @2.5" front; 1" coil spacer rear
New kicks:
17x8.5 -10 Stealth Custom Series Blaze10
285/70/17 KO2
Just got these installed today on my '07 V8 Limited. C load K02s in 265/70-17s on Matte Gray TRD Pros. No lift, just bought the truck, but I'm shopping for something plush in a 2/1 for now. VERY SLIGHT rub on the front of the fender liners, but it'll ride til I get it picked up a bit. Glad I went with C load instead of Es, rides almost like the oem-spec LT Michelins that were on it when I bought it last week.
2003 Limited 4WD
New kicks:
285/70/17 KO2
Not the setup I wanted or what I plan on running for llong...
3" RC lift
Pro Comp 17 X 8.5's
Falken AT
I hate that the rake is still present w/ the lift however I am chalking it up to the weight of the front bumper......
New set up coming soon...
2004 Sport V8 2WD
Bilstein 5100 @2.5" front; stock springs all around
17x8 AGP Pro Bronze
265/70/17 Falken Wildpeak A/T
Hey, a few questions. Replacing shocks and springs soon. 180k stock.
1) I'm going with Bilstein 5100s shocks. At 180k, should I replace my stock springs?
2) I've read that 5100s can stress other parts of the suspension?
2) Should I do anything else while I have it apart? Something like replace the 1A 10 Piece Steering & Suspension Kit? 2008 Toyota 4Runner Front 10 Piece Steering & Suspension Kit TRQ PSA59529
Finally....
OME 885/895, Fuel Block D752 wheels, Falken WildPeak AT3W 285/75/R17. OME UCA's, new LCA's, new tie rods and axles.
Just picked it up from the shop today. I will have to do a bit more trimming, but it rides great.
(Hope the attachment works)....
nice work06 with bilstein 5100s OME 2884 coils up front and 36-281817 in the rear. Low setting on the bilsteins. Tires are Nokian WR G4s 265/65/17. Looking for New tires before winter this year
Just added new BFGoodrich HD Terrain KT on 255/80r17. Got about 2 inch lift in front and 2.5 rear with Dobinson coil overs and Bilstein's 5100 at 0 level. Original upper control arms and only rubbing front mud flaps when turning at full lock. Need to test with flex if something else rubs. I got the gen 5th snow flake wheels( 17x7 with 15 mm offset) no wheel spacers.
