lifting my 85 need help
Fun Runner 85
Hey everyone I jus bought an 85 4runner and want to put a lift on it but I wanted to kno wat is the Best, easiest and cheapiest way to lift this truck. And wat size I was thinking a 5in but watevers the better way to go. if anyone could help with any ideas it would be more than apprecited. Thank you
What kind of lift? body? suspension? both?
Best, easiest, and cheapest don't really go together.
Give us a better idea of what you want to do and maybe a ballpark $ figure.
Then we can make some decent suggestions.
I'm hoping to spend around 700ish I don't want a body lift. suspension lift wat kind I'm not sure I don't even kno wat my options r. do I jus buy bigger leaf springs?
I'll help you Fun Runner 85
<a href="http://s94.photobucket.com/albums/l93/evalencia102001/?action=view&current=IMG_0893.jpg" target="_blank"><img src="http://i94.photobucket.com/albums/l93/evalencia102001/IMG_0893.jpg" border="0" alt="85 4runner"></a>
He wants a suspension lift. I think the budget $500.00 - 1000.00
Blocks or shackles with new lift shocks and a few other components that you will notice along the way will be the cheapest easiest way to go. you will probably come out at around 4 or 500 bucks at the most. Maybe a little more depending on the quality of parts you put under your rig.
Rough Country, Superlift, Trail-Gear, and plenty of others if you serach.
Better kits will have 4 spring packs, 4 shocks, dropped draglink, adjustable torque rod, u-bolts.
What about putting his rear springs in the front, and 89-94 pickup springs in the back ? Heard real good things about that setup.
With mild shackles, maybe 3/4" lift just for more flex.
Sorry I haven't posted a reply in a while. But I heard Shackles could mess up your casber r something like that. And pinion angles and blocks give you major axle wrap which gives you wheel hop. Since I'm looking to get a 5in lift. Is this correct.
Talyn
