LT5 said:
The factory installed parts differ from the replacement as the front hard line is in 2 sections rather than one, since the body is now on the frame. Each side has 5 components and are factory filled. All ends utilize a nifty check valve setup. I installed and removed a "B-Nut" a couple of times and no fluid leakage was noted. No external bleeding is required. Page 25-18 of the manual spells out what to replace in regards to system leakage. IMHO Yamaha and KYB designed a simple and easy to maintain system, and it works.
Your experience is what I saw when the dealer tech unbolted the front struts to add the lift on his workbench.
After reading all the posts here and Yota related to coil over struts and many of the hundreds of posts regarding lifts, I have come to a few additional conclusions. Oh yea, I have read a number of coil over posts on other forums too.
1) I am still getting rid of the front struts with the spacer lifts. They will sit in the garage to be used when my coil overs ever need to be rebuilt. Just like how I keep the stock suspension parts when I upgrade the shocks on my motorcycles.
2) The NE 3" spacers will remain in the rear. I am waiting for replacement coil springs that provide a non-sagging lift.
3) The NE relocation bolts will be sent back to Anthony along with the rest of the front lift parts. Maybe he will be kind enough to refund my purchase price.
4) I am still upset that the dealer said that the entire Xreas system would have to be replaced after only one shock leaked. Braking systems are every bit as complicated and you don't have to replace everything if one part is replaced.
5) My order for the first of the Donahoe 2.5" coil over struts is in. They are shipping on March 1st.
6) I spent yesterday in the Ozarks on the mountain roads and trails on the land I am a partner in. First by myself, then with a carload touring the property. All of this was done with no shocks as all the fluid has long since drained away. The ride and drive was still excellent.
7) The shudder I have been concerned about is probably due to the reduced and now non-empty shock fluid. On freeway bumps I now get a lot of shudder.
I'll start a new thread with a photo and thoughts about this last off road adventure.
