Lightbar bracket help
Doc_Fry
I know a few of you have made brackets for a lightbar for under the grill. I need help. My fabrication skills are not up to par anymore due to injury and I am not allowed to play with some items. I have a 32" light bar and would be willing to reimburse some one for help fabricating a bracket.
Nothing not evpictures or hey doc you just need this many aluminum bracets cut to s and so length and using so and so bolts to put together. Etc, comeon on. Everyone here has an opinion except when it really mattes.
I did three separate pieces of angle L aluminium for each side of light bar. One laying flat on support as a base, one going up as a vertical riser, and one attached to side of the riser, flat side up for bar to bolt to. Maybe a foot of angle aluminum per side (thats plenty), bolts of your choice, a hacksaw or sawzall, and a drill for the holes. That's how I did mine. I looked at [MENTION=103267]Saker[/MENTION] build to be honest and he had some good ideas.
Thanks for the kudos [MENTION=3054]Lexusbstrdchild[/MENTION]!
Hey Doc, sorry for not posting!
Look in my sig it will take you to my link on my LED bar install. Maybe someone can help you fab something or you can have someone look at Lexusbstrdchild setup...remember you can always but a flat bar across the top to facilitate more options!
I have a picture of mine mounted, but it's on a Limited and I was able to use the bracket that came with the lightbar. Simply drilled and atpped two holes for it.
Link to my lightbar mount
Thanks for the replys. Going to do something this next month after I install the electrical as this is the only running vehicle I have. Plus, i cannot make multiple runs to the HW store.
After looking at the replies the lightbar I have mounts on the side. Here is the diagram. Also, I cannot use the lower bumer for mounting as I will be installing a hidden winch system there.
TerryNap61
