lights out!?!
There's two bulbs behind that screen. Go pick up two more from the dealer and replace them. From what I understand that panel pulls off..
Yeah man, i got you.
Youre going to need a small clear LED bulb (got yer dealership, part # is 90010-09017). They cost about $5 for a pair...i got a couple the other day.
Then you need to take the small cubby out form under the HVAC controls...just pop it open and pull it gently UP and out. There's a 10mm hex screw there...pull that out and you should be able to tub the entire HVAC control right out. Its a tough pop, but it comes out.
Follow this setup to get the bulb changed. Good luck!
Center Console Lights
