What size and type of tires are you running?
Wild peak 275x20
will I be the first one to try this? cutting out a slot in the front chrome bumper cover and will insert a custom made aluminum housing into the hole where the light bar will be held. gonna look very clean and be very functional (doesnt block rad etc.). Pictures as soon as the aluminum box is ready and im brave enough to start cutting into the bumper cover. Pumped about the end result
Finally installed the 275’s on my truck last week.
Really Really this truck started life as a limited.
Got it done today. Gonna look pretty great mounted in the front chrome grille. Gotta polish it and the cut into the plastic for mounting. Fingers crossed.I thought about doing that too but wasnt sure how it would look. Good luck cause id love to see how it turns out!
Wow. Love this. Went in too easy. The insert made the grill just as study, if not sturdier then before too.![]()
Sent from my STV100-2 using Tapatalk
Started with a Dremmel/cut off wheel then went to a Multicrafter tool with an oscillating blade. The plastic is very easy to cut. There are 3 layers of plastic to go through and I just went one layer at a time. Make sure to move the wiring out of the way that is clipped into the last layer in the engine compartment.How did you cut out the bumper area?
Sweet. I was contemplating about putting a light bar in the front and this helped solve my dilemma. I didn't want to use the grill space above the chrome trim because of the TOYOTA letterings I added and didn't want to do below because I eventually want to add a hitch receiver.
Sweet rig. What size tires are those?Still have the LE wheels :behindsofa: but added a few other things.
Sliders
Satoshi grill, full rack and awning.
Sent from my SM-G950U using Tapatalk
One more question. Where did you get your grill from?Thank you, they are 275/55/20.
