Limited Edition Mod Thread
She looks much meaner now.
I will 2nd this, looking to do a trd full front swap but I would be super happy with that!
That will cost you thousands though.
You can just just put a TRD Pro garnish on and plasti dip all the chromes. That would look awesome.
Did you order your parts from your local dealer? How much did it it cost you?
I bought a TSO Pro grille which is an aftermarket product and the upper radiator from the dealer. I still can’t justify the price of these two pieces of plastic though.
So it’s overall $650.
thanks man, looks awesome. IMO it is def worth the money.
I see that some of you have already color matched or blacked out your door handles. i posted this on a different thread but no luck, hoping i can get some help here.
I have a 2010 Limited with the touch sensor door handles and really wanting to switch out the chrome for the black TE handles.
I’m thinking the LE door handles might be slightly different from the rest because of the sensors? Has anyone with a LE have any info on this?
I figured it out and I thought I’d post it just in case others are running into the same problem. On LE handles you’ll have to disconnect the sensors before you can take of the outside door handles. Once you’ve removed the inside door panel and you get behind the handle, the handle is held on by a clip and the actual connector. In the image below, it shows that I’ve unhooked the clips (right) and the next step is to disconnect the connector (left). Once you do that, you should be able to remove the door handle.
Got my FNs on Saturday.
The rest of my suspension should be coming in this week.
Updated my mod list;
- Wheels & tires: FN wheels, 17” Type X, Mich 265.70.17 Mich Defender
- 1" front spacer lift
- LED Lighting upgrades: Interior, license, puddle lamps
- LED Turn as tail mod (Diode Dynamics)
- LED Xtreme Pro low beams (XenonDepot)
- LED switchback running/signal lights (Diode Dynamics)
- LED Fogs (Alla lighting bright yellow)
- Horns - FIAMM El Grande (not much different than stock)
- Proclip phone mount
- Toyota all weather floor liners
- Bug deflector - AVS
- Bully hitch step, Curt hitch lock
- Blendmount /V1 w/mirror tap
- Mud flaps (Roadsport B series)
- Husky cargo mat
- N-FAB Nerf step bars
Not installed yet: Blackvue DR900S 2ch 4K dashcam
Truck looks fantastic
Appreciate it. I took some of the chrome trim off this weekend. Sanded them down, primed and painted with rattle. Looks pretty good, but getting all that chrome off is a huge PITA. I've only done with Limited lettering(which I broke, got some more on the way, and the chrome strips near the bottom of the front bumper.
I really need to save up for rock sliders/skids. Need to protect the investment.
So far these are my upgrades/mods:
Some blacked out chrome(long term process)
Daystar Leveling kit(Getting Toytec BOSS on this weekend with UCAs, and the BCM)
OEM Plus Audio JBL Enhancement(sounds great, Daniel is great to work with).
FN FxPro 17x8 with 285/70/17 KO2's(AWESOME, Dustin is also great to work with).
Shrockworks TE Rocker Panels(they don't line up great, but provides the clearance I need)
CB/Antenna(still working on mounting when I have time)
Rago Fabrication Modular Roof Rail System(Very solid. Great company).
Rago hitch step
Fyreflys Interior LED kit(has worked flawlessly).
I can't say enough good things about the customer service of Daniel(OEM Plus Audio) and Dustin(FN Wheels). They have been extremely helpful throughout my ordering and installation process.
Dustin spoke with me and the shops about my install, making sure everything was done correctly.
For the Limited OEM Plus kit, there isn't an official set of instructions or videos. Daniel and I spoke over the phone and facetime, for a couple hours a day at least while I was doing this install, explaining to me, step by step, what needs to be done.
That's all for now, I just wanted to give a special thanks to these guys. They have and continued to go above and beyond to keep their customers satisfied.
Here is what I have done to my 2018 Limited so far;
MODS COMPLETED
- Wheels & tires:
- FN wheels, 17” Type X Light Gun Metallic
- Mich 265.70.17 Mich Defender
- Interior, license, puddle lamps
- Horns - FIAMM El Grande (not much differnt than stock)
PLANNED: 1" front lift, 2ch 4K dashcam
Do you have a pic of the proclip? I’m debating on mounts. Thanks
Sure. Here are a few. Nice thing about these is that the 'mount' is separate from the 'phone holder', meaning that when you upgrade your phone, you only have get a new 'holder'. Pro-clip stuff is pricey for what it is, but it works perfectly.
Got my TT BOSS suspension with SPC UCAs on yesterday. A full 3” lift. Got it done at Tandem Offroad, did a great job and were some cool guys.Also picked up there rock sliders. I was looking at others brands, but these were ready and look great.
The truck is almost done for a while. I’ve got trips coming up this summer so have to rest my wallet for a bit.
Want to finish correctly blacking out my chrome using carbon fiber vinyl(you can see in the rear pic my $5 oreilys carbon fiber sticker i used to see what it’d look like).
Eventually I’ll get some skids plates, and led lights as i need it.
Awesome! Thanks! I think that’s what I’ll end up with. I like the no drilling.
tuṣṭāva
