Location of charcoal canister on 2000 SR5 V6?
drmoreau
About to start fighting with the p0440, p0441 & p0446 codes. Got a new gas cap ordered but I'm assuming the canister will be the culprit. Where is it located on the 2000 SR5 V6? Thanks.
On my 2000 Limited it's in the engine compartment, driver's side wheel well. Box looking thing with a bunch of hoses on it and a plastic green cap for the test port. Really cant miss it as it's above the VSV solenoids for the 4wd and next to the engine compartment fuse box. On the older Runners (not sure when they changed) it's underneath the truck by the rear axle. Good Luck!
Pretty sure that's the canister up above/near the spare tire/fuel tank location. Or that's the EVAP thing. Not sure if that's what you mean?
US models have canister above driver wheel well under hood. CA models have them under spare tire if my knowledge fits me right. Best bet is find a low mile OEM, got mine for $20 and fixed all my codes. My last one was actually cracked.
Well since mine is a CA model that would explain why I thought that's where it is.
My 2001 CA-spec has the canister above the spare. I think I may have fixed my evap codes though without replacing it.
I had the other valves in the setup replaced waaaay back when I kicked these codes under extended warranty. Wouldn't you know that the codes came back when the warranty was up.
I just cleared the codes whenever they popped up for some 70,000 miles. I finally got sick of it and tried a hillbilly fix. I took the canister off the rig and sprayed half a can of non-chlorinated brake cleaner in the ports and valve openings. At first, the fluid came out brownish. Then I found a small tree leaf inside the canister (I have no idea how it got in there!) - which I naturally removed with needle nose pliers. Once the brake cleaner was coming out clear, I sat the canister on my driveway in the sun on a hot day (it was in the low 90s) for about 4 hours. I turned it upside down back and forth a few times to get out any residual cleaner and let it sit an additional hour in the sun.
I suspect this is enough to partially re-activate some of the carbon in the canister (cleaner then heat). Regardless, my MIL hasn't come back on yet (knock on wood) and my gas mileage is up by about 2mpg.
Good luck!
Good luck!
did that fix hold up for u?
Does anyone know exactly what signal this sends to the ecm? Seems like we could eliminate the system with a few resistors.
Edit:. I found an old thread that shows how to bypass and remove the charcoal canister. Just search evap delete.
patnewton
