locked up
Member
I got both front sunroof drains cleared.
It has rained since then and I didn't find any wet spots so I think I'm good there.
Somehow the PO had cracked the fuse box cover/base.
So that got replaced as well.
I'm now trying to track down a Bank 2 Lean condition (P0174).
I also replaced the driver side O2 sensor ... so both fronts are new.
(Side note, thread chaser is < thread tap. Just FYI)
I have the rear sensors too but have not put them in.
Cleaned the MAF.
Also replaced the PCV valve, PCV hoses and a few misc bits of hardware and clips.
I'm thinking it might be a vac leak since I did replace a few brackets under the hood.
Maybe I popped off a hose or bumped a brittle one?
That or a fuel injector.
Ugh.
Time to bust out the smoke tester I guess.
Cleaned the MAF.
Ugh.
