Long crank starting problem
Coyotegray
My 2017 has started taking noticeably longer to start. Outside temp doesn't make a difference. About 85k on it. I changed the spark plugs since it was cheap and easy. No change. Air filter is new. Cranks fast. not a battery issue.
Any ideas...?
So, I cleaned the MAF sensor, cleaned the throttle body, and while I was there replaced the PCV valve and used some Seafoam injector cleaner. So along with new plugs this seems to have cleared up the problem...
Thanks,
Andy..
Bunkstaff
