LTDSC
FINALLY got time to hit the shop and lower my seat. What a difference! I feel like im so much lower. I see out of the middle of the windshield, not the roof, i no longer hit my head/hair, can close the sunroof and NOT hit it. Im so happy i was able to do this and i took plenty of pics for everyone.
Seat removed
Friend grinding the edges of the brackets
You can see our cuts on the lower bend here
Hit it with a hammer to flatten it out, can also see our second cuts on the outer most bend on the closer bracket. Farther bracket is flattened as well.
Test fit to make sure thats enough
left is original, right is the one we cut and bent (huge difference)
Little welding to sturdy the brackets and make it right, also welded the top cuts after picture.
Bore out the mount holes a little and tape up the side panel to trim. Used washers on the seat bolts to cover the bigger bore.
I taped and then cut the side panel with the dremel and a disk.
Closer look at the bracket now
Installed, you can see where i cut a little too much off. I also sanded down the burs/edges from the dremel cut. The picture makes the edge looks a lot more noticeable.
Seat removed
