It flashes a bit after startup when you are nearing 5000 miles since the last reset, then stays solid once you hit 5000.
Any chance you forgot to reset it? It does sound like it thinks it's time for an oil change. I don't think there is much else that could trigger it?
Well, if you did reset the light, then maybe the 4Runner is suffering from memory loss.
You guys are way over thinking the light. It is only a mileage driven feature that turns on solid every 10k miles. You must have not cleared it all the way when you changed the oil.
you're suggesting I only cleared it part way? lol.
so it was off for 3800 ish miles, instead of the full 5k.....
No not at all. I'm suggesting that you held reset thinking you reset it and didn't. Either way...Sounds like you know way more about cars than I do anyway. Check the "oil condition sensor" after you top off your headlight fluid...
I've been changing my own oil lately. How DO I reset that maint light? 03 limited
