Merry Christmas...Radiator recommendations please?
RoyR
Had the water pump replaced as part of preventative maintenance, when they did the belt, and I think the stealership damaged the radiator...either way, not paying a $1000 for the OEM unit....
Can you recommend a good aftermarket unit?
PS. I intend to use the factory coolant and vacuum fill the system after installation. This SUV is beginning to cost me some money!!!
If it is pretty obvious that the stealership damaged the radiator, I would be down there talking to a service manager, then escalate it to whomever from there if he cant help you. If you decide its not worth the hassle, like the post above RA would be your best bet.
matisgugle
