Microsoft forcing updates again
ran
Senior Member
This is a 2010 Lenovo M72e Ivy Core i5 Win 10 1607. So far this is the higher Win 10 version they have drivers for. I am using a MS program to stop 17xx version from installing. I guess they are working around that now.
I was running utilities and stepped away from this PC. Came back to find my browser off and 'Installing updates, this will require multiple reboots.' I powered down and booted back up to see 'trying to restore previous version' (I really wondered if Win 7 was coming back) About 15 minutes later it finally booted up OK. good old M$
_________________
2007 SE V6 titanium
It did that to me yesterday but I wasn’t paying attention so it updated. Haven’t noticed anything different but haven’t really dug into it yet.
I absolutely hate Windows 10. Prefetch is the worst. I have to spend a good five minutes every morning cleaning memory before logging on to the Internet.
I'm about to build a new desktop system based on an 8-core Ryzen CPU. I intend to install Ubuntu Linux on it rather than Windows 10. Wish me luck...
Any of you MS genius can help me? I got the free Windows 10 upgrade, was Win 7 before. Now the computer just shuts down for no apparent reason. I haven't actually seen it happen. I usually go in and out so I tried just lock computer, then sleep or just let it go to screensaver... but about every 5th time it'll just shut down... Grrrr. I did a disk check, then a memory check, then everything is updated and no threats according to Defender...
What next?
It's my work laptop. Acer Aspire 5552-7474. My only Windows machine just so I can run the random Windows only software. All my other rigs are Macs. I had it running dual Linux which is much more stable but I can't get drivers for certain things so I can't use all of the laptop functions...
What next?
try looking into the event log, under control panel\administrative tools (depending on the version, could also be a right click or a menu option). Look for anything with a red icon on it around the time it shut down
it says 12 times since 1/9/2018. (I upgraded end of year)
Kernel-Power event ID 41 bugCheckCode 159
Gibberish to me....
BugcheckCode 159
BugcheckParameter1 0x3
BugcheckParameter2 0xffffcb83f6df8b50
BugcheckParameter3 0xfffff8003aa06a30
BugcheckParameter4 0xffffcb83fc99f4e0
SleepInProgress 4
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 0
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 1
CsEntryScenarioInstanceId 0
BugcheckInfoFromEFI true
CheckpointStatus 0
Gibberish to me....
BugcheckCode 159
SleepInProgress 4
BootAppStatus 0
Checkpoint 0
CheckpointStatus 0
I remember seeing this on a dell. the solution for that was to disable dell power management. I would suspect your issue is quite similar. it may be an installed update, or it may be running in the tray. basically this is a bad driver and your vendor never updated it to run with 10. the native driver, the one that comes with windows will do whatever you need
let me know how you make out
Yeah I tried messing with the power management before via Windows 10. didn't do much but with your suggestion I straight up uninstalled the acer power management. Fingers crossed
So far this new 1709? version runs faster on my Core i5, 16 GB MB. Happy. Guess I stop waiting for the other shoe to drop.
you will be fine, the only thing you need to watch out for is the laptop reinstalling it
Man I was rolling for like 3 days and then CRASH.... same error essentially. I didn't witness it because like I said I like to leave my computer on...
Either
-on Sleep
-on Lock
-On Screen Saver after which eventually it sleeps
F-ing MS
Either
-on Sleep
-on Lock
F-ing MS
check to see if it reinstalled the power manager. I will try to find out what I did to resolve this on the dells, I thought it was just uninstalling it, but now that I think of it, there may of been something else
try changing your power options to not run performance or not balanced, I seem to remember that being an issue, or something I tried, not sure which
Laredotx
