Misfire with no check engine light?
alms_lefko
Is that possible?
Seems like the only logical explanation... I replaced my plugs (100k) and now i'm getting an intermittent stumble at idle, and the car struggles and kinda bumps and jerks getting up to speed. But I don't have a check engine light on...
Timing belt changed recently? Does the CEL/MIL even work? Lol had to ask...it should come on for 3 seconds then turn off when you start the car.
Have you run the fuel tank damn near empty and then filled up with premium at a different station than normal?
Also what are your driving habits? Grandma-ish or do you let that baby breath once in a while?
We need the following:
~Model Year
~Engine (Give you a hint, only two flavors :P )
~Trim (SR5, Sport, 4WD or 2WD
~Mileage
How severe is this misfire? When it stumbles does the engine sound like its going to stall or is it just a sort of light stumble at idle? When you say you feel it jerking and bumping when getting to speed is it a light feeling from a stop, do you get a similar feeling when stopping?
well NOW it came on... misfire cyl 2
thinking coil... wow are they expensive!
its an 05
v6
sport edition
100k miles
Black (since it's the best color) ;)
First redo your work on the plug on that cylinder. Make sure the coil is inserted and plugged in correctly. May be an issue with the connector.
#2 is front driver's side (LH Bank)
If you do use anti-seize, only a very small dab and not too close to the tip. According to NGK, the only plugs that need it are the ones with no nickle coating (they have a black, bare metal body). I've seen misfires from using too much anti-seize and/or getting it on the tip of the plug.
this is what I was getting at
Go easy with do electric grease, it's designed to impede current flow. Also check plug gasp, it's rate but not all plus are properly gapped from the factory to consumer.
