Morimoto Elite HID install
I just followed the instructions for the drill size, used a hole drill, took my time drilling since it is plastic, and had "0" issues.
The grommet fits tight and seals....
If you ever decide to remove the system, go back to OEM, it is easily done.
Where do you snake the wires through if you don't want to drill?
Is the headlight assembly not a closed unit???
Cheers
I think when you pull the covers off, you will see a grommet at the bottom with the OEM harness coming thru it....
Someone correct me if I'm wrong here!
Sounds right from what I read here - and I did see a grommet at the bottom when I looked. However I don't know how you would then substitute the grommet that comes with the kit. In any case, I am going to go with the drill -seems easier that way. Thanks for the link to your mod! Helped a lot to visualize things.
The kits you can buy come with grommets on the wires, the grommets can either: be inserted through the hole you drill, or inserted through the hole already there after you pull out the stock grommet with the wires from the bottom of the housing. From my experience, the TRS kit grommet is about the same size as the stock grommet in the bottom of the housing. I have read that the grommet from the other kit (xtreme led?) is not quite the same size.
But then there is a lot of fishing and fiddling that you would need to do. If you replace the OEM grommet with the kit grommet, you would have to fish the OEM wires back inside the light housing; if you want to use the OEM grommet, you would need to fish the kit wires inside. Either way, trying to reverse them is a PITA.
So I looked at it closely, and I ended up deciding that drilling thru the socket cover is the cleanest, and easiest way for the installation; and actually the easiest way to "reverse" the procedure too. All you need is to buy 2 new cover, and the procedure can be "reversed" in like a few minutes.
:yo:
:yo:
I will continue to report any and all of your comments that you choose to make behind my back accordingly. Good day. :)
[MENTION=103267]Saker[/MENTION] Saker bro, thanks for liking my post. If I have hurt your feelings, just keep liking my posts. Do not start a war. Love.... don't hate....
:banana:
:banana:
If I am not a part of a thread please do not use my name in that thread. It's a pretty simple request. If you are educated enough to understandable the request that is...
The moderator has been advised. Feel free to pm me with any questions.
What the heck?
Wth is exactly what I said when I read your post on another thread. By the way a buddy of mine just bought a t4r and he lives about 8 miles away from you. I showed him your pictures and he was just wondering if he could come check them out? Let me know. I don't wanna impose.
Does this ring a bell?
"I bet [MENTION=123801]undertheradar[/MENTION] and [MENTION=118113]Wis4[/MENTION] can be great friends.
[MENTION=118113]Wis4[/MENTION] took off his running board, [MENTION=123801]undertheradar[/MENTION] can just buy it from him, and then they can talk about HIDs."
Is this a threat?
You are NOT my friend, and your friend is NOT my friend. What make you think that I want to let your friend check out XXXX?
But, Molon Labe!
Why are you even invading/posting in [MENTION=97032]hearno[/MENTION] 's HID installation thread? Moderators closed and deleted your threads, and only short of banning you; many of us are ignoring you, not wanting to engage in any conversations with you........ take a hint!
Is this a threat?
But, Molon Labe!
I read it as a threat. Not sure what his deal is, but every post and PM I have ever read from this guy, you can tell there is just a little something off.
Reported to mods. [MENTION=118113]Wis4[/MENTION] you know this is the internet right? Just checking.
Just report him to the mods. It's fine to let some things go as they are funny and harmless but when people go off and start threatening it's time to break out the ban hammer. [MENTION=119516]jicko[/MENTION] sometimes it's best to just ignore these guys man and don't stoop to their level.
Is this a threat?
But, Molon Labe!
I honestly want him to check out how safe the HID's are. That's not a threat. You claim they are safe. I respect your decision to claim they are safe and hope you respect mine.
Actually the mods are well aware that jicko used my name on a forum that I was not a part of hence starting the issue. I will repeat [MENTION=119516]jicko[/MENTION] please do not use my name on any threads I was not a part of.
Is this a threat?
But, Molon Labe!
Banning me was not ever brought up and will never happen. To be honest the mods are also wondering why you even brought up my name on a thread j was not a part of???? Why did you do that if your not looking to spark an issue. Huh Mr. Perfect?
Maybe you want it to happen so you can continue lying to other members about how safe something is that is actually not. I know my rights and hopefully you know yours. Please respect my opinions as others have opinions too.
Hello, as I've already mentioned the mods are more interested in why [MENTION=119516]jicko[/MENTION] is using my name in threads I was never a part of.
AndiGarage
