Morimoto Elite HID install
Update #2. One of the looks blue and the other looks yellow........ Also if I shut the engine off, after like 2 minutes the drivers side bulb shuts off but the passenger side stays lit... This is enough to make me go back to stock. Wtf.
[MENTION=118406]Haydenatx[/MENTION],
Time for a call to TRS for some support!
They will help you.....
Hayden,
I can't really give much for an answer on the bulb color difference but as far as your second problem, it could be a faulty relay.
Pop off the relays and switch em around, they unclip and tug on it to release it from the harness. If the problem switches to the driver side then its a relay. If so, i have a spare relay in the garage i can mail you since i just put in a new set.
Was going to post this. Switch relays and see what happens. I had to recently replace one. I was have intermittent firing of the ballast. A trip to autozone and five bucks later all is well.
I did hit up TRS several times and they told me to swap the bulbs then ballasts.
I swapped the bulbs from driver to passenger yesterday and it has been working since. Drove home from a wedding an hour through dark country roads and the visibility was unreal. Knock on wood that it stays working. I think I had a bad connection somewhere. Thanks for the help saker and [MENTION=117698]Moto69Joe[/MENTION] !
Hey all, bringing up an old thread. I'm interested in the XenonDepot, however they're going to cost me $200. I have a local shop that has the Morimoto H11 HIDs, which I would be interested in as well.
Just looking for thoughts and opinions on which to go with. I've also read that you don't need the relays for 2014+, is this the case? Thanks in advance.
so i had this kit for about a year now....main issue is the cable from the relay it really should be a tad bit longer. i am unable to mount both ballast above the fender. i am now starting to have issues where the passenger side will light light up. if i let it sit sometimes it will start to flicker and eventually power up.
when it decides to light up it has a faint flicker. i have swapped the igniters and the problem still is on the passenger side. so i swapped ballast and its now on the driver side. so i believe the issue is with the ballast. so i contacted TRS and waiting to see what they say. so i later put everything back to its original location and when i went to turn on the lights nothing came back on turned off the light and tried again. then the driver side came on. but now i cannot dupliate where no lights come on. just back to the original issue where the passenger wont turn on. hopefully theres not other problems other than the ballast.i havent had much faith in this kit. i had the same model kit on another car as fogs and it never once gave me an issue.
Holy necro thread bump, Batman!
I just got a TRS HID kit to install in my 14 Limited. I've used their kits in several other vehicles and have been super happy with their products.
I also need to change out the side marker bulbs (one is out) - do I have to pull the headlight assembly out to do that or is there another way to get to the bulb? I looked around under the hood last night but couldn't find access to it.
Disregard - I found the answer in another thread.
Sent from my iPhone using Tapatalk Pro
erinobr2000
